90mm Q45 throttle on LS2 intake?
Old Oct 25, 2004 | 07:37 PM
ballistic69's Avatar
Default 90mm Q45 throttle on LS2 intake?
Anyone tried this or think it might work? They have 4 bolt holes, but I don't know if they line up.
http://search.ebay.com/q45-body_W0QQ...1QQsonewuserZ1
Old Oct 25, 2004 | 08:42 PM
Squintz Palladoris's Avatar
There are other things to think about like: IAC??? there does not look to be one on there. TPS??? What kind of voltage output does that thing have, and have fun wiring it up.
Bolt pattern? I am sure you could get the measurments from someone.
Brad
Old Oct 25, 2004 | 08:58 PM
guadofreak's Avatar
the Q45 TB has an offset squaer bolt pattern. I may buy one just to play with it. Might be fun. AFAIK the LS2 intakes and such are on a "square" bolt patter so it won't mate up. the IAC and TPS as was said may be quite the interesting job though!
I will have to look at my buddies Q45 more closely next time.
Old Oct 26, 2004 | 07:50 PM
1CAMWNDR's Avatar
Hhmmmmm, I don't think so. Looks like the Q45 bolt pattern is exactly square; and the LS2 intake is more of a rectangle:
Old Nov 1, 2004 | 09:07 PM
guadofreak's Avatar
Got more info. no IAC or fast idle in the TB
TPS = .40-.45 idle 4.4-5.0v WOT
Also the Q45 does have a rectanglur mounting bolt pattern also..HOWEVER in the opposite direction of the LS2. "IF" it were to bolt up directly the throttle wire would be sitting underneath the opening. Trust me I did my research for a cheap viable solution but to no avail.
Old Nov 1, 2004 | 09:53 PM
30th TA 0219's Avatar
what about an adapter plate, like a TB spacer?
Old Nov 1, 2004 | 10:48 PM
guadofreak's Avatar
still have no IAC...that might post a problem. Anythign can be fabricated. Just having enough room to have the MAF and lids etc match up is another thing.
Old Nov 1, 2004 | 11:29 PM
Green Thunder's Avatar
Why?
Man I wish I had your time!
