photochop or reality??
6-piston front and 4-piston rear calipers
• Cross-drilled rotors
• Aluminum engine block with 104.8-mm bores and pressed-in liners
• Forged steel crankshaft with 101.6-mm stroke
• 6-bolt, forged steel main bearing caps
• Titanium connecting rods
• Cast aluminum flat-top pistons
• Racing-derived CNC-ported aluminum cylinder heads with 70-cc chambers
• 56mm titanium intake valves
• 41mm sodium-filled exhaust valves
• 11.0:1 compression ratio
• Composite manifold with 90 mm single-bore throttle body
• Camshaft with 15-mm (.591-inch) lift
• Dry-sump oiling system
• 7000-rpm redline
WEIGHT: 3130lbs/1420kg
500hp/475lb-ft torque.
Given a picture of a C6 of that color, with those wheels, I think I could recreate that image with about 2 to 3 hours of work.
It's a very accurate representation of the final car. Especially given the camo'd spy pics shown on th gm insider news forum.
http://forums.gminsidenews.com/showt...?threadid=8066
Edit:
I've gained some interest in determining if this is real or not... here's an analysis between the actual spy photo and the picture in quiestion.
http://img112.exs.cx/img112/3259/dig...s_analysis.jpg
Also, pay close attention to the area directly behind the front lip of the fender. The wheel is blacked out in some locations. (typical of a shopped set of wheels)
Another possiblity is that the black bumper skirt could extend around the front of the car and into the fender.
There are good arguements either way... regardless I'm not to impressed with the overall look of the car.
Fry
They used titanium rods because with a 4" stroke spinning at 7k rpms thats a hell of a lot of inertia. The titanium rods are light and strong. They didn't use forged pistons because they are more prone to knocking on cold starts than cast. Gm is very nervous about knock issues based on their ls1 truck problems. But with an engine with titanium rods, forged crank, and 11:1 cr, your going to have to change the pistons to reduce your cr for boost And you already have a stout bottom end from GM. Not so good for you Nitros guy :-(
And with the apparent hysteria from GM about this pic and data being posted I suspect both it and the data is exactly correct. I imagine that the picture will appear in many magazines in their Feb dated issue (as long as that issue is not available prior to Jan 15th.)
Perry
I doubt the 475 ft-lb number myself. A 7.0L should be making that much without even working hard - at least if you assume the noted specs are true. I would not at all be surprised to see production numbers closer to 500 ft-lb - if not, I can imagine it either being heavily underrated or simply "detuned" in an effort to reduce load on drivetrain components. Either way, with only 500hp this engine would appear to have some serious potential with only minor upgrades (thinking even just cam, exhaust, tuning or something to that effect) - especially if the rumors are true on how well the LS7 heads flow.
http://www.corvettels7.com/
im in love
