True? LS7s come with a version of C5R heads?
This will be the first time in history that a factory 500-hp will be so susceptible to aftermarket modification.
Who knows, some could be around 600 rwhp with heads/cam... and that's daily driven.
Ive got this 4.125 bore 387 sitting here with a really crap set of heads on it. I was wondering what to do.
Apparently I should just hang out until I can buy the stock LS7 top end.... if and when it's available.
chris
chris
Also, keep in mind the crank is a dry sump, so you will need to modify it to get it to work in a non dry sump block.
But, yes, the possibilities are amazing...
Also, Louis- you mentioned that the intake ports on the LS7 heads are a C5R/SB2 derivative?? I wasn't aware that the C5R heads and the SB2 heads had anything in common other than both being GM pieces. Does that mean that the C5R (and therefore LS7) head is an 11° design as well??
The LS7 intake port is a derivative of those 2. Valve angle I am not aware of. From my understanding, the LS7 intake will bolt up to C5R heads. I would not doubt that the LS7 Heads will fit the LS1 block either. If the Race case at a 4.125 bore on a 4.4 center is good enough for LeMans, it is good enough for OEM. Same bore centers, no need to change the bolt spacing. The only thing they did was suck up the bolt holes and use short bolts for all 10 in the head itself. The 5 smaller ones up top will remain the same. Exactly like the LS2 and a few select LS6 blocks.
The angle at which the exhaust manifold bolts too is the same as well. Port diminsions are obviously different, but its the same as far as bolt on parts are concerned.
