C6 MAF is 95mm, will it work on LS1?
Old Dec 28, 2004 | 02:45 PM
Payton's Avatar
Default C6 MAF is 95mm, will it work on LS1?
Spoke with a parts guy at the chevy place. MAF on C6 in 95mm as oppossed to 85mm for a C5 Z06. Do any of you know if they would plug in and work?
This may be in the wrong place. Feel free to move it or direct me where to post.
Payton
Old Dec 28, 2004 | 03:49 PM
JZ'sTA's Avatar
its a 90 mm and will work if you buy everything that goes with it to make it work.
Edit, I thought you asked about the TB not MAF.
The MAF is a 85 mm.
Old Dec 28, 2004 | 04:44 PM
70 LS1's Avatar
Conversion master
Just what does everything to make it work consist of?
Old Dec 28, 2004 | 10:03 PM
CSiJason's Avatar
I highly doubt 5mm is much of a bottleneck.
Old Dec 28, 2004 | 11:01 PM
Another_User's Avatar
5mm means a lot.
90mm = 6361.74 square mm flow area.
95mm = 7088.23 square mm flow area.
8% is 8%. It makes a big difference with a 90mm TB. A 90mm TB will easily outflow a 90mm MAF (don't forget about the divider, etc).
Old Dec 29, 2004 | 07:54 AM
SlickVert's Avatar
You will have to install the corect MAF code. I don't now if it will plug into the ls1 or ls6 harness.
Old Dec 29, 2004 | 07:55 AM
Pumba's Avatar
Payton
The C6 MAF is 90 mm, and it attaches with four bolts.
The C5 Z06 MAF is 76 mm, and it attaches with three bolts.
In addition, the wiring to the two MAFs is different. That will need to be reconciled.
Old Dec 29, 2004 | 07:56 AM
Payton's Avatar
Default 95mm maf
The parts guy told me 95mm which makes sense if the TB is a 90mm. I will double check, but I asked him twice to verify the first time.
He did not have one to look at, but I would assume that it has the same plug as a Z06 MAF. Anyone out there have a C6 that could verify?
Old Dec 29, 2004 | 09:25 AM
NO-OPTION-2002's Avatar
Hello,
The C6 LS2 MAF is GM part # 25318411. It is the same part # as 01-04 C5 Maf and 01-05 Truck MAF. There is no difference in the MAF - Meaning it should only be the 85mm we have been woking with for a while.
Hope this helps.
Old Dec 29, 2004 | 10:58 AM
Jerseyboy's Avatar
Originally Posted by NO-OPTION-2002
Hello,
Hope this helps.
You are correct, I have a C6 MAF sitting in my lap right now. It's 85mm ID at it's smallest point, just like 01-04 C5's.
Jersey
Old Dec 29, 2004 | 11:08 AM
Jerseyboy..
Thanks for the verification, the GM catalogs have been known to be wrong from time to time. It makes things interesting for sure!
Old Dec 29, 2004 | 08:10 PM
Mike TexaSS's Avatar
8 Sec Tuner
The MAF is 85mm...
Old Dec 29, 2004 | 09:45 PM
SJRTX's Avatar
the MAF can definitely be worth it if you have the setup to take advantage of it. Heck, We dyno'd my car with the stock MAF, and then installed the ZO6 MAF and re-dyno'd, and picked up 15rwhp on a mustang dyno with no other changes except for programming the computer to make the MAF work correctly.
Old Dec 30, 2004 | 07:59 AM
Payton's Avatar
Default maf
Thanks for the input guys
Payton
Old Dec 30, 2004 | 08:00 AM
WhiteDiamond's Avatar
Like he said...It is only 85mm...Use the search function.
Todd
