LS7 = 8500 rpm
"Just chatted with the engineer that is on the GM account. GM does spin the DoD lifters up to 7500rpm. They run a modified square wave test (idle to 7500rpm) and hold @ 7500rpm for 5 seconds. Test is repeated three times. They are only looking for part failure and not valvetrain dynamics. So in theory the DoD could go into the LS7. But the weight of the DoD lifter is still too high to get stable valvetrain dynamics so they won't put them in."
Also asked him how high GM spins the LS7. He said they run brief excursions to 8000rpm but again they aren't concerned with valvetrain dynamics only part failure. Durabilty runs are at 7000rpm. He confirmed threshold was 7500rpm for the LS7 hydraulic lifter. So brief 1/4 miles blasts where the rpm only touches 7500-8000rpm momentarily (no hanging rpm) are possible.
Something else to consider is that they have all of the bearings, cylinder walls, piston skirts, cam lobes, valve stems etc, impregnanted with teflon. For some strange reason, the average guy running a street/strip car willl spend $2K on a set of heads, but will not spend $200-300 to protect all of these components.
the rules aren't in print yet.
Ooops, sorry not trying to hijack the thread.
Do you guys see the correlation between big bore, small stroke now? You are NOT going to spin a 4.000" stroke engine to 18,000 rpm!!!!
Or make over 800 HP with a 183 ci engine!!!!!!And that 183" F1 motor probably makes more than 1000 hp.
thanks Chris.
unlike drag racing which only really requires a crazy 1/4 mile spurt at a time.. or street driving, where your not driving a 10/10 100% of the time (although street has its own set of requirements)
*rubs eyes* btw, I never noticed Dave Farmer here till now! (me oblivious)
That 4" stroke is a killer. Not only because of the piston speed but because of the angularity. Those Cup motors also have a high rod/stroke ratio.
With a 4.03 bore, my 355 (3.5" stroke) has 515gm 6" Honda-journal rods, 370gm pistons, 87gm pins, and a 36.25# crank. People who went with a 352 (4.155x3.25, we must use a 'stock' stroke) and used the Superfly pistons (320gms, maybe) and Maxi-light -1s or equivalent (485gm) end up with a 32# crank.
This sort of rotating assembly will cost $6-7000 in LS1 sizes. However the crank will be 50-60#. With that, the bottom end can handle the speed.
On the top you have lightweight high ratio rockers (increases spring leverage and reduces lifter/pushrod travel), light valves, lifters, double tapered pushrods, ICD Ti retainers, Ti keepers (saves 2gm), valve spring oilers, coated or micropolished springs of high quality (say $500-1000/set).
This sort of valvetrain will cost $5-7k. Speed costs money...how fast do you want to go?
The Cup teams custom order all their pieces in fairly large batches (how many rods do you think Hendricks, Roush, Everham, Childress, or DEE order at a time?) They are able do build custom setups that the rest of us can't.
Those F-1 engines are 300cc cylinder. The LS7 is 875cc. So there is a lot less stroke, not even counting the different bore/stroke ratio. With much better angularity. And even with a direct action DOHC valvetrain, they have to use pnuematic valve springs to rev that high.
David
metro 6R4 3.0 V6 (very nice race engine that will rev to over 10K). around 25ms-1.
so i recon pushing over 26ms-1 will lead you into trouble. but if anyone KNOWS better then please tell me. shame though as i bet one of these things at 8K would sound very nice!
thanks Chris.
My view on high revs is "what's the point?" for a street car I preffer making power down low, but I can understand for heads up racing you want to make as much power per displacement as you can.....
-Adam
Thanks Chris.
PS my motorcycle is 67.0mm x 42.5mm with a 15,000 RPM redline........see I'm so dumb I can't even convert metric to standard
-Adam
My CBR-600RR
Piston Speed Rounded FPM: 4,183.071
Piston Speed Rounded FPS: 69.718
My M3
Piston Speed Rounded FPM: 4,773.333
Piston Speed Rounded FPS: 79.556
My Trans Am With a blown wrist pin
Piston Speed Rounded FPM: 0.000
Piston Speed Rounded FPS: 0.000
humph I really thought my CBR's pistons would have been moving faster than the M's....wow, guess not.
-Adam
you dont need a calculater to do it.
mean speed is distance/time.
so figure out the time takes to complete 1 stroke - 1/(max rpm X2 /60)
and divide the sroke by that (in seconds). dead easy!
Chris.
PS. if i have got this wrong correct me, im not with it today!
