LS2 block vs. 6.0L Aluminum Truck block.... what are the differences?
Old 01-06-2005, 08:55 AM
ElEsWon's Avatar
Default LS2 block vs. 6.0L Aluminum Truck block.... what are the differences?
When going after a 6.0L swap, what would the differences be between using the new LS2 block vs. the 6.0L aluminum blocks currently used in trucks? Are they essentially the same?
Also, when using a 402" stroker kit in these blocks, do either of them require any clearancing or are they like the 6.0L Iron block which requires no surgery to go up to a 402"?
Old 01-06-2005, 10:02 AM
org
org's Avatar
Unless something's changed in the past couple of months, the 6.0 truck blocks are cast iron.
Old 01-06-2005, 10:21 AM
Blue Hawk's Avatar
Right now, the big issue with the LS2 block is the knock sensors. They won't work in a non-LS2 car and you have to disabled them in the PCM.
Old 01-06-2005, 10:50 AM
ElEsWon's Avatar
According to Chevy Hi Performance, the 6.0L Iron casting was phased out in favor of an aluminum casting for the end of '04 and up.
Old 01-06-2005, 11:57 AM
vmax1500's Avatar
What issue of CHP?
Old 01-06-2005, 06:01 PM
org
org's Avatar
That would be nice if true. I haven't heard that about the 6.0. The 5.3 I think is now aluminum. It's hard to believe the 6.0 would be far behind, since having a common block for all the 6.0 engines would be a cost saver for GM.
Old 01-06-2005, 06:10 PM
ElEsWon's Avatar
Originally Posted by vmax1500
What issue of CHP?
September 2004, pages 122 and 124.
Quote one, p.122-2nd paragraph: "Though the block material has since been changed to aluminum, early LS engine trucks were equipped with the LQ4 and LQ9 iron block engine..."
Quote two, p.124-figure 4: "The LQ4 or LQ9 cylinder block is cast iron rather than aluminum and was used in truck applications until 2003. Now all blocks are aluminum, but if your application calls for an inordinate amount of squeeze or positive manifold pressure, you might consider the efficiency of iron."
Old 01-06-2005, 08:13 PM
fast98's Avatar
ya he is right they are aluminum and have been for a few months at least, i work on them all the time
Old 01-06-2005, 08:35 PM
ElEsWon's Avatar
So is that pretty much the same as the LS2 block then? How about cost.... still in the same ballpark?
Old 01-07-2005, 02:09 PM
Gran Patron's Avatar
The new 2005 silverados come with all aluminum motors!!! Wich i think is great!!The new improved 5.3L is awsome. THe only thing i dont like is those drum brakes!!!
2003 RCSB (stepside)
3:73,G80
5.3L Stock for noww!
Old 01-07-2005, 03:45 PM
BigTex's Avatar
The 04 6L trucks have an iron block, so do the 05 6L trucks. Not all 5.3s have been switched to aluminum. The SSR was the first vehicle to have the aluminum 5.3, since then, select trucks have an upgrade option (with a price) to get an alum 5.3.
As far as I know, only the LS2 has a 6L aluminum block. If a plain aluminum 6L was available, we'd know about it before CHP.
Old 04-08-2009, 02:42 PM
bigwill1983's Avatar
if you delete the knock sensors from the PCM would that cause a problem after awhile?
Old 04-08-2009, 03:05 PM
GMCtrk's Avatar
This is incorrect. The LQ4 or LQ9 never came with an aluminum block.
Old 04-08-2009, 04:19 PM
dubrado's Avatar
You have to drill for an alternator bracket hole on the iron blocks
Old 04-08-2009, 04:20 PM
dubrado's Avatar
3:73,G80
Wierd, they went backwards because my 00' silverado has 4 wheel discs...must be a cost saving measure.
Old 04-13-2009, 02:52 PM
1sick'98WS6's Avatar
This can be solved by relocating them to the side of the block with a drill and tap. I dont know that I would want to disable them.
Quick Reply: LS2 block vs. 6.0L Aluminum Truck block.... what are the differences?
