current price of c5r heads?
Old Feb 2, 2005 | 08:01 PM
Greg Fell's Avatar
Default current price of c5r heads?
I'm assuming the LS7 heads are C5R heads. Hopefully they'll be cheaper. Just wondering if its worth waiting for them vs the AFR 225's.
Old Feb 2, 2005 | 08:11 PM
The Guy in MY 99TA's Avatar
C5R heads usually run about 6 grand I beleive. The flow is much more though.
Old Feb 2, 2005 | 08:33 PM
cyphur's Avatar
They've said the heads are "race-derived" designs. I'm presuming a more emissions friendly version of the C5R heads. I thought the heads usually went for about $3k? $6k is a shitload for heads! I know the C5R block is $6k every day of the week.
Old Feb 2, 2005 | 08:37 PM
RX-Ben's Avatar
I remember someone was selling them relatively cheaply- I think around $2500 or so. But you need a custom manifold (or just run ITBs) as well. And valves, springs, rockers (Jesel). Adds up quickly to well over $6000 complete.
Ben
Old Feb 2, 2005 | 08:53 PM
Greg Fell's Avatar
Right, but i'm wondering/hoping that the ls7 will have all the stuff we need to make it doable...intake, rockers, heads. doable = 5k for all or less, etc.
Old Feb 2, 2005 | 11:16 PM
BurnOut's Avatar
As I understand it, the LS7 heads are C5R based, but are by no means the same pieces. For one, the chamber volume on the LS7 heads (70 cc as stated in press releases) is considerably larger than on C5R heads (38 cc or 30 cc, depending on the part number); of course, the C5R heads could potentially be worked to have the chambers opened up that much, but that's a lot of metal to remove. Also, the LS7 heads are advertized as having a 12 degree valve angle, whereas the C5R pieces are advertized at 11 degrees (I don't know if one of them is a typo, or if there is really a difference).
EDIT: I just checked the price of C5R heads, and at GM Parts Direct they are $1200/each bare. At that stage they still need to be ported in addition to needing valve springs, valves, rockers, etc...
Old Feb 3, 2005 | 07:23 AM
Lafngas98Z's Avatar
I've got a set of brand new bare casting for sale for $1700+ shipping.
Old Feb 3, 2005 | 08:07 AM
mikey's Avatar
LS1TECH Sponsor
What casting number Rob? The new one or old one?
Old Feb 3, 2005 | 08:22 AM
Lafngas98Z's Avatar
Mikey these are 12480005.
Old Feb 3, 2005 | 03:23 PM
ForceFed HP's Avatar
Suspended Sponsor Account
also when you buy them as a bare head, there are exactly that, bare. no seats or guides.
