Trigger Wheel
Old Feb 10, 2005 | 02:50 PM
ProStreetZ28's Avatar
Question Trigger Wheel
What is the diffrence between the LS1 and LS2 trigger wheels?
Old Feb 10, 2005 | 03:47 PM
Unaffliated Racing's Avatar
trigger wheel?
Old Feb 10, 2005 | 07:41 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Reluctor wheels on the crankshafts are different, different tooth count. LS2 pcm system is different.
Old Feb 10, 2005 | 09:01 PM
O6blues's Avatar
I have disassembled two LS2's and they have the same reluctor wheel as the LS1/LS6. Have you seen something different?
Old Feb 11, 2005 | 02:54 PM
Do you know what tooth count reluctor they went to? Did they switch to a 36 minus one wheel?
Old Feb 11, 2005 | 03:45 PM
LS1Tech Co-Founder
I was told the tooth count is different. Did you count the teeth? LS2 is 60x.
Old Feb 11, 2005 | 05:18 PM
LS1Tech Co-Founder
Big correction: Am now told that the LS2 crankshaft is 100% interchangeable wtih the LS1/LS6 stuff, and that the LS7 will be 60X.
Hope that jibes with what you are seeing Nicky.
Old Feb 11, 2005 | 05:22 PM
427's Avatar
427
The LS2 is still using 24x wheel from a LS1. The next wheel is 60-2 or 58x. I think it will be introduced on the LS7 engine first but you never know if it will be pushed back.
Kurt
Old Feb 11, 2005 | 05:38 PM
XLR8NSS's Avatar
Adkoonerstrator
The video posted of the LS7 engine being built has some pretty good shots of the crank. It certainly looks to have a 58x wheel on it. Doing the best I could counting/estimating off that blurry not so good pic it certainly looks like 58 teeth.
The video can be found in this thread for anyone who hasn't seen it yet.
https://ls1tech.com/forums/generation-iv-internal-engine/259608-z06-engine-video.html
Old Feb 11, 2005 | 10:11 PM
O6blues's Avatar
2-11.05
I have had several of the new reluctor wheels here (60X-2) to look at, it is significantly thicker than the current 24X. I also was told (as mentioned by 427) that the new wheel would first be used on the LS7, BUT I have also heard mention of a mid-year change on the LS2 -- who knows!
I recently had a customer that purchased a complete LS2 production engine from me and his engine actually had the 60X-2 wheel, personally I think it was a freak accident! I have had numerous engines in our shop since and they all had the 24X wheel.
