ls2 vs ls6 dyno numbers?
Old Mar 5, 2005 | 08:23 AM
Blackbird5.7's Avatar
Default ls2 vs ls6 dyno numbers?
On average the ls6 seems to put down more power than the ls2? why? They have the same heads? Aren't the valve sizes the same? If so can your squeeze larger valves in the ls2? There's a lot here I don't understand, Please help.
Old Mar 5, 2005 | 10:43 PM
ChucksZ06's Avatar
The LS 6 has a larger cam than the ls2 which uses the cam from the 01 z06. From the testing people have been doing it seems that the LS 6 intake is also superior to the ls2 intake. This apparantly more than offsets the higher compression and extra displacement.
