The LS4
Old Mar 9, 2005 | 02:24 PM
org's Avatar
org
Originally Posted by zamboxl
yea me to don't see that happening in a gm built family car.
I haven't heard the rumor, but it's a lot cheaper per car to build composite components on a few hundred thousand units than on a few hundred.
Old Mar 9, 2005 | 02:38 PM
ducaT's Avatar
Not a structural component like the chassis.
So when your wife goes and rear ends somebody, the pre-preg chassis needs to be completely replaced and therefore has to have the whole car disassembled and reassembled on a new chassis?
Insurance rates would skyrocket and the car would get a bum reputation right from the outset.
On top of all that there would have to be a SERIOUS retool in order to have pre-preg autoclaved manufacture on a scale to bring the returns required to make it happen.
GM's bread and butter for the past 10 years has been the truck market.
How exactly does a CF investment make returns there?
Then there's the steel union. Can you imagine dropping the demand for steel from GM by probably 50%.
No way in hell.
But back on topic. I'm pretty sure the block in the Impala is the same as the truck motor. When I saw it at the LA auto show, from what I could tell, it looked nearly the same.
Old Mar 10, 2005 | 06:50 AM
chuntington101's Avatar
CF is great and it will become more comon (in high end cars) as time goes on. the problem is the manufatureing prosses is so much more labour intersive and requires larger amounts or resourses. its great stuff for low volume pruction but for mass it would coz har to much. Aluminium (so im english) is a better material to use for a car chassis and can be easier than steel if you bond the components instead of weld them! also much lighter.
thanks Chris.
Old Mar 11, 2005 | 10:39 PM
Bill Reid's Avatar
I could see the accessory drive (with modified aftermarket cranks possibly), making its way into rods with tight fit specs... and perhaps maybe someone will toy with trying make more room in the already tight C5/C6 engine compartments for power adders... a big single hairdryer at or near the stock location of the original waterpump would be cool to see. Whatever comes of the LS4 means folks will have more options to amke things work for their projects I would think
Old Mar 12, 2005 | 12:57 AM
Full-Force's Avatar
Originally Posted by NavySS
Yeah I read that article, kind of sad... So who wants to go protest/riot in front of GM for an LS2 Camaro with a forged bottom end and a twin screw blower or turbo?
i just settle for a rear end worth a chit
Old Mar 12, 2005 | 01:55 AM
WS-Sick's Avatar
Amen!
Old Mar 12, 2005 | 04:24 PM
leaftye's Avatar
Originally Posted by StickSS
From what I heard the new GP, Monte and GTO will be rear drive coming out 2007 or 2008. Rumor has it that it will have a new full frame tubular race car like chassis made out of carbon fiber. 3 times stronger than steel and lighter. Will have to wait and see on this one?
If they use frame rails like on the C5/C6 or trucks, they could make them using a pultrusion process. It'd be more complicated to pultrude parts with bends, but it's just part of designing the tools. They could make the rails solid or hollow, and make long continuous runs to cut later, but cutting them will be a PITA if they use anything but a water cutter. It can have wound layers, as well as layers where the fibers run straight along the rail, so it should be strong dimensionally in all directions. The one thing I don't see is it being very light since it's not feasible (or even possible??) to autoclave a pultruded part. Anyway, pultrusion machines can cure the part while it's being made. If they use pultrusion, carbon fiber rails can be very affordable, especially if they find a good source for carbon fiber tow. Any other process I can think of requires much more human interaction, and complicated design and manufacturing methods (read "expensive"), so I think pultrusion may be the only way to go for frame rails. If it's anything but frame rails, I don't know how it can be affordable...
Old Mar 12, 2005 | 06:46 PM
Wild85's Avatar
They are putting the 5.3 engine into the GTP and Impala SS for 2006 and its gonna be rear drive also.
Old Mar 13, 2005 | 07:25 AM
Patrick G's Avatar
LS1 Tech Administrator
While it's true the 5.3L engines are going in the GTP, Monte Carlo and Impala, it is NOT true that they will be RWD. They will in fact be FWD.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 13, 2005 | 09:33 AM
Camaroholic's Avatar
There's a fair amount of LS4 info in this thread:
http://www.fiero.nl/forum/Forum2/HTML/058437.html
I think if I were gonna swap a V8 in to my Fiero, I'd do the LS4 & transaxle setup.
I also think that the most significant advancement is the Displacement on Demand feature. V4 to V8 automagically. The technology there is pretty cool. I think that's more interesting than the FWD configuration.
Old Mar 13, 2005 | 01:40 PM
Phoenix 5.7's Avatar
i don't trust DOD. i want to see how a DOD engine is holding up after 100k, then ill trust it.
Old Mar 13, 2005 | 01:57 PM
  #32
Third Gear's Avatar
That would suck if they put that on the LS7
I bet when HP Tuners comes out for DOD vehicles, that's the first thing they'll disable is DOD.
Old Mar 13, 2005 | 04:17 PM
  #33
prince xizor's Avatar
DOD might not be that bad if they do it right. If it kicks in when Cruise is enabled than whats the problem? This technology has been around in Caddys in the 80's the V-8-6-4 if I am not mistaken. Besides whats wrong with getting a few more mpg with the way the petroleum prices are?
