what cam for ls2 without changing springs, etc?
Fry
The spring is capable of being used with most of the milder aftermarket grinds. The specs are 100# seat pressure @1.800" and 300# open pressure @1.244" The seat pressure is only 5# less and open pressure is considerably greater than the Comp Cams 26915 spring. The only limitation may be the maximum lift of .570" since spring bind occurs at 1.179"
