I can not believe this
:boiling
. I cant believe I missed that. My question is since I made 303rwhp on 7 cylinders about how much should I have made on all 8? Trending Topics
Your equation would be true if the piston/rod had been left out of the motor altogether.
Formula-T/A, I guess we now know why GM didn't make the LS1 a V7 engine, huh??
1. You're going to have the friction losses whether the cylinder is firing or not. In fact, due to the lateral movement of the piston at ignition and during the power stroke, the friction incurred is actually higher than if the cylider didn't fire.
2. The work required to compress the air during the compression stroke is actually regained, to some extent, during the power stroke. Because both valves are closed betweed TDC and to a point just before BDC, that higher-than-atmospheric-pressure air charge in the cylinder is helping to move the piston back down. [the spark plug is still sparking, so there is some expansion of air due to the heat transferred from that, as well as from the heat in the combustion chamber warming the air in the cylinder, if you really want to pick nits]
So, you're right, the eight sevenths calculation is not entirely accurate. But it's close enough for him to estimate the amout of rwhp he would have been making had that eighth cylinder been firing.
Do you agree with that, too, itchygomey?
-Sly
. my bad
