05 GTO ET's
Old May 27, 2005 | 08:05 PM
rumblebox's Avatar
Default 05 GTO ET's
what do stock 05 GTO's run in the quarter mile?
i'm guessing high 12s....
Old May 27, 2005 | 08:26 PM
Dave68RT's Avatar
mid to low 13s probably. depending on driver
Old May 27, 2005 | 08:48 PM
rumblebox's Avatar
i've seen 04's(LS1) run mid 13s. i assumed the LS2 would push the 05s into the 12s.
Old May 27, 2005 | 09:12 PM
04Yukonxl's Avatar
I have an almost stock 05, just headers and turned a 14.7@99.9 at Bandimere. Corrected for altitude is 13.08@110.88 sea level. That is with severe wheel hop which is about to be fixed.
Old May 27, 2005 | 09:15 PM
rumblebox's Avatar
how do you get rid of the wheel hop? i've heard it's horendous.
Old May 27, 2005 | 09:16 PM
rumblebox's Avatar
is yours auto or stick?
Old May 29, 2005 | 04:42 PM
WS6Jonny's Avatar
Is it possible to get rid of the wheel hop without ridding the GTO of the IRS? I know Corvettes and Vipers have IRS with minimal wheel hop so I'm wondering how that works out.
Old May 29, 2005 | 05:00 PM
Kurt D's Avatar
I beleive BMR makes a kit to eliminate wheel hop on them and CTS-Vs.
Old May 29, 2005 | 05:47 PM
Tom@SpeedInc's Avatar
If your a good driver and make some fast shifts 12.9xx 106mph has been seen.
Old May 30, 2005 | 05:52 PM
Joel_SS's Avatar
13.1 @ 104 here bone stock A4...
http://www.ls1gto.com/forums/showthread.php?t=18674
Old May 30, 2005 | 08:39 PM
04Yukonxl's Avatar
It's an M6 and the wheel hop fix is Koni adjustables and springs. I have all sitting in my garage waiting for me to get the time to install them. Others have found various solutions but most have had good luck with the Konis.
Old May 30, 2005 | 08:42 PM
04Yukonxl's Avatar
Shifting fast is not my problem, I've raced sticks for decades. The problem is 60 ft. times, related to stock all season tires and wheel hop. My best 60 ft was 2.1 sec, with the right suspension and DRs that should be 1.8.
Old May 31, 2005 | 11:37 PM
dubrado's Avatar
for the most part, stock 05's seem to go low 13.0-13.2s at around 105
while the 04's seem to go 13.5-13.8 @ 103-105
