LS7 / C6R Velocity Stack Induction/Injection
Old Dec 8, 2005 | 05:02 PM
  #121
BLk01SS's Avatar
Originally Posted by Quickin
I'm still curious about my question in post #113.
The intakes look the same.
Mainly because its lighter, and because it more than likley uses all CNC'd parts. I'm sure its good stuff since they use them on those world class vettes.
Old Dec 8, 2005 | 05:14 PM
  #122
technical's Avatar
Originally Posted by J-Rod
Anyhow, many times a box is used to filter and direct air, along with holding a restrictor for some class racing. The IR stuff in many cases will make more HP without an airbox and being exposed to outside air with no box. I have some dyno graphs that illustrate this if you'd like to see them.
That helps on the low end yes, but what about on the high end? IT was my understanding that IR intakes had a harder time once the RPMs climbed.
Old Dec 8, 2005 | 07:29 PM
  #123
Quickin's Avatar
I'm sure they're amazing, I'm just wondering what the difference in FLOW is...they look identical. I don't see how the C5R intake can be a whole lot better if it is at all.
Old Dec 8, 2005 | 09:53 PM
  #124
Beast96Z's Avatar
That's the thing about ports. You never know how good one is until you flow it. You can have alot of ports that look the same, but do something completly diffrent. You have to look at the parts that are being used in the Katek intakes. That carbon fiber alone is going to be hella expensive, not to mention molding, cnc custom pieces, fully hand shaped ports, and so on. Tons of time goes into just one of those pieces since they are one off. That's why the price is so high.
Old Dec 9, 2005 | 04:15 AM
  #125
TUF383's Avatar
So what makes this intake different than the Butterfly intake we're all talking about.....power-wise?
Very light (Magnesium & carbon fibre).
Suits C5R heads.
Made for hungry engines.
NOT emmission compliant.
Hurts the wallet.
... and a few hundred extra hours worth of development ...
Old Dec 9, 2005 | 09:16 AM
  #126
Quickin's Avatar
Suits C5R heads.
Hurts the wallet.
It would be pretty funny if they flowed the same though. Kind of like the C5R block, it offers zero in extra HP over any other LSx block. Now the C5R heads are basically the same as other heads (LS7 and ETP 265/41's) for 1/3 the price.
I love it when that happens. Makes it better for all of us.
Old Dec 9, 2005 | 11:18 AM
  #127
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Harrop gave me some info, it was basicaly how much clearance over the valve covers you needed it was something like 55MM or something of the sort. But I think you can call them, and they can fill you in.
Old Dec 9, 2005 | 12:06 PM
  #128
MeentSS02's Avatar
Kleeborp the Moderator™
All ya have to do is email them, and they'll give you all of the engineering drawings with all of the dimensions. Even half way around the world
