LS7 / C6R Velocity Stack Induction/Injection
Old Nov 25, 2005 | 12:16 AM
  #81
Argon Z's Avatar
Kinsler.com made intakes for indy racing leage and c5-r race cars. They do offer ls-1 manifolds in both aluminum and magnesium
I am running a mag one on my car when completed. The advantage is increase hp, with amazing throttle response.
Old Nov 25, 2005 | 12:27 AM
  #82
Argon Z's Avatar
Here is a cool engine. Ultima gtr with kinsler intake. With a turbo on top 1000hp?
http://www.spectrum5racing.com/Proje...gtrproject.htm
Old Nov 25, 2005 | 09:17 PM
  #83
Katech_Jason's Avatar
LS1TECH Sponsor
No, the very first one was Kinsler. All the other intakes for C5-R and C6.R are engineered and manufactured by Katech.
Old Nov 25, 2005 | 09:39 PM
  #84
ilovefirstgens's Avatar
Katech, please indulge us on what you do with the maf, as it seems like aside from a buttload of fabrication that is one of the major necessites, could you run a dual setup such as i believe the first generation vipers used?
Old Nov 25, 2005 | 11:15 PM
  #85
Argon Z's Avatar
Katech
I said MADE not make
Old Nov 26, 2005 | 11:09 AM
  #86
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
You get rid of the MAF by converting your tune to Speed Density. No more MAF then....
So, if anyone has info on cheap TB's then post it up, no matter where they are...
Old Nov 26, 2005 | 11:42 AM
  #87
LS1TECH Sponsor
You're right. It's speed density.
Old Nov 26, 2005 | 12:03 PM
  #88
J-Rod's Avatar
Just to clarify, the stock GM computer will run in SD (speed density) just fine with some programming help from the avaliable tuning products.
My buddies in Australia have been doing so for years. With their help, we've been introducing SD tuning to folks here in the states for the last 2 yrs or so.
In fact one of the engines I saw over there was C5R headed motor with a custom 8TB setup. At the time there was no intake avaliable for a C5. With one of those setups, you could run the,m. Of course now with the LS7, we have an intake option, but, Harrop has a really nice C5R 8TB setup ready to go which would be awsome on a car.
Once converted to SD, you ditch the MAF, and can run a 8TB intake. As I stated ealier her eis a shot of a street car in Australia running a stock GM computer in SD mode, and a 242/242 106 LSA 105 ICL cam in a 346
http://users3.ev1.net/~black_ops/video/242-106.mpg
So, you could do a C5R or resleeve block with Ls7 or C5R heads, and a Harrop intake, and put it in a car, tune it with say HPTuners, and have super streetable car with crazy N/A HP that would idle like stock even with a big cam.
Old Dec 3, 2005 | 06:21 PM
  #89
Sharpe's Avatar
Awesome. Thanks.
I love it when you talk dirty.
So, you would have to have an LS7 or C5R block and heads for the Harrop velocity stack induction/injection? Damnit!!!
Old Dec 3, 2005 | 06:48 PM
  #90
TUF383's Avatar
Nup ... The Harrop Hurricane bolts straight on to an LS1/LS2.
It will also feed a 427ci, but not with C5R heads (yet). We are planning on a C5R/LS7/L76 version, but it is a little way off.
Old Dec 3, 2005 | 06:57 PM
  #91
Sharpe's Avatar
Damnit again!!!! Just when i thought my dreams had been dashed, you had to go and give me hope again!!!
I'll never be able to afford one!!!
EDIT: Does anyone have one of these in an F-Body? Any picks if so?
Old Dec 4, 2005 | 11:04 PM
  #92
J-Rod's Avatar
I thought when I had spoken with the folks at Harrop, and with other folks down there, that y'all had already done the C5R port design as part of the HSV project which was going to carry the manifold. It was my understanding y'all already had the C5R manifold avaliable. Is that not the case?
Old Dec 5, 2005 | 03:01 AM
  #93
TUF383's Avatar
You are correct ...
We do have a C5R manifold but it is not the Hurricane as initially shown.
The C5R manifold is not a mass-produced item, each one is hand-built and port matched .. typically for race applications.
Here's some images ...
I love my job ...
Old Dec 5, 2005 | 07:18 AM
  #94
Phoenix 5.7's Avatar
, that thing is gorgeous. i don't want to even think about guessing how much that cost
Old Dec 5, 2005 | 09:48 AM
  #95
Damage Inc.'s Avatar
Sweet Cheeks
I think he said "around $10,000" earlier.
Old Dec 5, 2005 | 10:41 AM
  #96
NOSjohn's Avatar
Restricted User
I think i just messed my pants.
Old Dec 5, 2005 | 10:43 AM
  #97
J-Rod's Avatar
Y'all do some nice work guys... That is a piece of artwork...
Old Dec 5, 2005 | 12:00 PM
  #98
Sharpe's Avatar
I saved those pictures in my **** folder.
Old Dec 5, 2005 | 12:14 PM
  #99
NOSjohn's Avatar
Restricted User
@ Sharpe
Old Dec 5, 2005 | 03:21 PM
  #100
MeentSS02's Avatar
Kleeborp the Moderator™
Damn...I wish I could test fit this on my f-bod. I really like the looks of it, but the more I look at it, the more I think it just won't fit because of the cowl.
