Darton large bore LS2 dry sleeve is here!
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
We run the import engines with a lot less aluminum between the dry liners with no problems.
I just learned that one of the teams racing the VQ35 Nissan V-6 with Darton MID liners I installed surpassed two thousand horsepower on the dyno. You guys have some catching up to do!
Steve
Keith
Steve Demirjian
Oceanside, Ca.
760-630-0450
I have attached a photo of a Darton sleeve that has been squashed in a press. Note that it is not cracked or broken in any way. Try that with ANY other liner and it would shatter into pieces. Really tough stuff and not easy to machine either!
Steve
Keith
Steve Demirjian
Oceanside, Ca.
760-630-0450
The LS2 block does not have that coolant passage. It is solid aluminum between the cylinders. Also the diameter of the parent aluminum cylinder wall has been increase in the LS2 by .200" to 4.800". That leaves almost a quarter inch of aluminum surrounding the new Darton sleeve.
Steve
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve went WAY out of his way to help me get my new block repaired. I didn't even buy the block from him, or anything for that matter. I can't imagine what he wouldn't do for one of his customers. Thanks again!
this new ls2 dry sleeve is really the most economical route for displacement for street/strip use.
when ls2 blocks become more plentiful and worn in, the price will be bit cheaper as stress relief wont be required and you wont be paying full price for the block.
again, this if for street/strip. for the guys who want to run large amounts of boost or n2o your better off spending the doughh on the wetsleeve. which in itself is a good deal considering its stronger and more stout then the c5r block at half the cost.
Our Iron sleeves are incredibly expensive for a bulk tube and very hard for my sleeve supplier to keep in stock due to price/availibilty.Thanks
Dave
Dave
