Cam suggestion for new LS2
Old Jul 18, 2005 | 09:33 PM
Steve1969LS1's Avatar
Default Cam suggestion for new LS2
Getting an LS2 to stuff in the 68 Camaro so now I need to figure out a good strong cam for her..
Will dyno motor.. install cam and ported heads.. dyno.. install in car.. dyno.. swap out intakes.. dyno..
It is for a story.
Sugestions on a good cam choice.. I want lots of power but I also need to keep some low and a good amount of midrange power since I will be doing road track time far more than drag racing.
Im not up on LS2's.. what good stuff is out there? Also.. the stick I get will most likely be from Comp Cams..
Thanks for the input!
Old Jul 19, 2005 | 08:57 AM
DrkPhx's Avatar
I would keep it mild and try a 224/224 or 228/228 on XE lobes with AFR 225's. I bet that would be a nice setup along with Long tubes. I'm curious to see what gains you get by switching to a LS6 or LSX 90mm intake.
Old Jul 21, 2005 | 02:52 PM
rgrizzard's Avatar
I am thinking of doing the same thing with a 67 GTO. Keep us updated to your progress...
Thanks,
Rich
