LS6 top half for LS2 short blocks?
Can I use old LS6 heads, cam, intake, injectors, fuel rails, rockers, push rods, lifters, plastic lifter holders, etc on a LS2 short block?
Does the increased displacement of the LS2 motor max out these parts which were designed for 350CI displacement engines?
As of yesterday, SDPC has sold 51 LS2 short blocks. I'm assuming most buyers are eliminating the knock sensor tests with LS1Edit or similar software programs.
Thanks
I read that SDPC short blocks include all the stuff needed to install them in older cars and that these parts included 1) LS2 valley cover, 2) front cam sensor, 3) front timing cover, 4) timing set with front cam sensor room, 5) oil pump.
If SDPC includes these items I assume these specific old items do not work on the new block.
Would it be possible to cut out the LS1 knock sensor holders from the LS1 valley cover and have them welded into the LS2 cover after drilling the holes for them?
LoL... jk i have no idea... sounds like more hassle than its worth...
Voy i dont think it would be worth the hassle i have done one at the shop and it turned out fine hit me up and i'll let you know what i did.....
