ls2 crate motors
Old Jul 27, 2005 | 02:18 PM
power trip's Avatar
Default ls2 crate motors
just wondering if I will run into any problems on the install???
What are my options to replace the electric throttle body to mechanical,
and where I can get a reasonably priced alternator, delphi computer???
Old Jul 29, 2005 | 02:01 PM
KJ's Avatar
KJ
Depending on what you want to install the LS2 in, you should have no problems. The LS2 is basicly the same as an LS1/LS6, so you can use any Corvette, F body, or truck accessory drive (alt., a/c, p/s, balancer). As for the mechanical 90mm tb, I have them in stock from Nick Williams. It will bolt up to the LS2 intake no problem. The main thing you will need to do is extend your map sensor harness, and your knock sensor harness. On each side of the block install a LS1/LS6 knock sensor. After that you should be ready to go!!
