AFR 225 Heads Set-up For Dry Sleeved 427 LS2
Anyone have recommendations for setting up AFR 225 heads using premium, lightweight components? I was thinking Ferrea 6000 Series intake valves (size 2.080) and Ferrea competition Plus Sodium fill hollow stem valves for the exhaust valves. Proposed valve springs might be Comp Cams 921. I would probably want to use 7 degree titanium retainers and 7 degree valve locks. Rocker arms would be ??
Thanks!
Thanks!
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Thanks!![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Thanks!
