LS2 stock manifolds vs LS1
Old Aug 3, 2005 | 12:08 AM
89FormulaLS2's Avatar
Default LS2 exhaust manifolds vs LS1
Has anyone done any testing yet on the LS2 stock exhaust manifolds?
Since I'm moving to California, I can't (legally) run LTs. Just curious how the LS2 manifolds compare to the older ones. Got a feeling they are all going to choke my 402ci LS2 a bit, but would still like to see some numbers if anyone has tried them.
Old Aug 3, 2005 | 01:12 PM
John B's Avatar
Moderator
Might want to look at the GTO headers
Old Aug 3, 2005 | 01:35 PM
Christos's Avatar
I bet you could get a ported set of exhaust runners which would do ok.
Old Aug 3, 2005 | 02:59 PM
StickSS's Avatar
hi: Hot Rod did a test on an LS2 crate motor and they put on Z06 manifolds from a 2001 + motor and they gained like 5 more HP also they gained like 8-9 HP buy running a ls6 manifold and smaller trottle body. This was on an engine dyno not a chassis one. the Z06 manifolds seem to flow the best of the stock ones. The GTO manifolds are a tri-y design like the Z06 ones so they should flow pretty good. The outlet is only 2 1/4 inch on them from what I heard. Maybe you could open them up a bit to 2 1/2 or 3 inch. Good luck
Old Aug 3, 2005 | 11:51 PM
nunze's Avatar
that is a gorgeous car!!
Old Aug 4, 2005 | 09:22 AM
Anonymous's Avatar
10 second playa
I thought the 6.0 truck manifolds were the best OEM?
Old Aug 4, 2005 | 11:36 AM
Derek 357i's Avatar
I have a set of GTO manifolds and LS2 manifolds, and while I don't have flow numbers, the LS2s are much bigger and lighter. I measure the opening on the GTO manifolds at 2.0" and the LS2s at a full 2.5"
Old Aug 6, 2005 | 10:43 AM
Sounds like you are talking about intake manifolds. I already am using an LS6 intake. My concern is totally with exhaust, sorry for not being more clear on that.
Old Aug 6, 2005 | 10:46 AM
Wow, that's quite a difference. Thanks for the input!
Still curious if anyone has any actual flow numbers, though? I suspect that the LS2 exhaust manifolds might be the best of the OEM options, but I'd really like to *know* before we finish the car.
