LS motor in Colorado pickup
https://ls1tech.com/forums/showthrea...t=ls1+colorado
My point is you should be able to integrate the factory SS harness as a complete swap over. You might have to remove some of the 4x4 stuff for the AWD, but gauges, abs, a/c, etc... should all work...
Sorry, I guess I should have read your post a little closer. Nomad did have a lot of issues with the pcm. I don't see why your idea wouldn't work.Is the Trailblazer SS 2 or 4wd? I haven't heard much about it.
LS2 6.0L V-8 with 400 horsepower and 400 lb.-ft. torque that exhales through a custom-built performance exhaust from the catalyst rearward
Heavy-duty 4L70-E four-speed automatic transmission with floor shifter
Heavy-duty 9.5-inch rear axle with a locking differential for added traction and a short 3.73:1 rear axle ratio for rapid acceleration
Front disc brakes measuring over 12 inches that are sourced from the full-size Chevrolet Silverado; rear disc brakes from the Chevrolet TrailBlazer.
Lowered suspension riding on brushed nickel-plated 20-inch Silverado SS rims
Stylized interior with unique trim, bezels, and seats
Custom exterior package with unique grille, fascias, flares, rocker extensions and tonneau cover
J-Rod - I was thinking of the something along those lines by putting a LS2 crate motor in my Denali. That would make me smile.
