LS7 heads on 15*pistons
Old Sep 24, 2005 | 04:54 PM
Greg Fell's Avatar
Default LS7 heads on 15*pistons
I have a 422, 4.100 x 4.00. The valve reliefs are 15*.
If I run a cam with smaller lift, would I be able to use the LS7 heads?
LS7 heads + medium size cam would probably spank a set of 15* heads with a nasty cam.
Does anyone have prices on a 'top end' kit yet?
Old Sep 28, 2005 | 06:47 PM
Greg Fell's Avatar
I guess I could also run a 114 lsa, which I am going to anyway as I may spray.
Anyone else?
Old Oct 5, 2005 | 06:27 PM
Greg Fell's Avatar
Anyone? I've gotten feedback both ways.
Old Oct 6, 2005 | 02:13 AM
jhong321's Avatar
i would think your CR would be very low with -15 pistons and a ls7 head that has a 72cc ?(i think) i did the calculation and got 9.6:1 are you planing to go fi ?
Old Oct 6, 2005 | 08:15 AM
Craig@ETPerformance's Avatar
You will be able to run those heads without a problem. Just check piston to valve. Even though the valve pockets are not in the right spot on the pistons the valve stands up more.
Old Oct 6, 2005 | 08:17 AM
Greg Fell's Avatar
They are 70 cc. I'll mill them down to 65-66cc or so, to keep a 11.5ish:1 CR.
They are -7cc reliefs, not -15cc. The valve reliefs are for 15* heads.
