View Poll Results: What Block????
LS2
53.95%
6.0 Cast Iron Block
26.32%
408
19.74%
Voters: 76. You may not vote on this poll
What Block to go with?????
Old Sep 22, 2005 | 02:03 PM
Bryan @ Speed Inc.'s Avatar
Originally Posted by CONVERTED
Ding Ding Ding.. makes most sense... already done... cheap... holds lots of power... stroked and done... either way you will need to pistons no matter what you do.. so the cost to sleve/and new pistons i'm sure will out weigh the cost of stroking... a stroked 427 is still a 427... one is cheaper, heavier & can handle more power.. no heavier isn't a good thing but you win some you loose some.
thanks for making me look like i know what i'm talking about
yea the iron blocks hold A LOT of power. i wouldn't do a resleeved aluminum block.
Old Sep 22, 2005 | 02:37 PM
CONVERTED's Avatar
You can buy and LS1 with the new darton sleves on ebay right now for 3200 plus shipping.. bore is like 4.1ish.. or you can buy an LS2 bare for like $1000ish and an Iron even cheaper... I guess their is some huge added bene of using an LS1 instead of an LS2...
After I learned what was involved with increasing the bore on the Alum. blocks and the cost... I then decided it wasn't for me but it might be for someone else who thinks their is something magical about that particual block.
Old Sep 22, 2005 | 02:50 PM
well everyone wants to stay lightweight. a big inch all aluminum small block is MIGHTY appealing. god knows i'd kill for a c5-r or an ls-7... but i'm christian and follow the "thou shalt not kill" ...having said that, i don't have the resources for the big aluminum blocks. iron blocks are the way for me.
Old Sep 22, 2005 | 03:06 PM
MonsterZ28's Avatar
can you get a 427 iron block? I know slp sells a 402 ls2 iron block i think, should i go n/a or twin turbo it, which compression is for which??
Old Sep 22, 2005 | 03:51 PM
CONVERTED's Avatar
you can get a 427 stroked Iron block... but i'm not aware of 427 bored out iron.. As far as I know the only 427s are the C5r and LS7
as for lighter weight... Oh yes I agree... If I could shave 100lbs off my car without loosing my interior or anything else just by having my block made of a lighter material that would be great... but if I can make as much if not more power for alot less I'll stick with my iron...
Old Sep 24, 2005 | 06:31 PM
MonsterZ28's Avatar
Default What Block to go with?????
Im undecided with what block i should build up, my camaro just crossed the 80 thou mark on the clock so im starting to thin about it.
I want either a LS2, 6.0 Cast iron, Or the 408 block.
Whats the best choice to go with, i plan on giving it twin turbos.....
I will take other suggestions on motors, Or a good way to set it up for the turbos.
Old Sep 24, 2005 | 08:19 PM
AntiVenom06's Avatar
6pnt hO
Old Sep 24, 2005 | 08:29 PM
MonsterZ28's Avatar
LOL what a d*ck
Old Sep 24, 2005 | 09:14 PM
firefighter's Avatar
Everything I've ever heard sez if you are gonna go boost the iron block is the way to go much tougher if you are gonna boost the crap moutta it the extra 60 lbs will be negligable.
Old Sep 24, 2005 | 10:04 PM
Nate_Taufer's Avatar
Iron block is about 93 lbs heavier. A big hit if you ask me. I personally don't think you could break the newer ls2 block from power. Bad tune, but not from sheer power with a tt setup.
I would definitely go with the aluminum ls2 stroked to 402 or bigger.
And fwiw, the iron block and ls2 are both 6.0 liters, although there are small differences in cooling passages and other small details they are similar. just that one is aluminum and the other is iron.
Nate
Old Sep 25, 2005 | 01:43 PM
JarrettL's Avatar
Where will this car see duty? If this is your street car how often is max boost really going to be thrown at it? But I would agree with investing in the best possible tune you have available to you and to cut no corners in this area. If you don't have the resources to do the tune correctly then you're going to have short-lived fun.
Old Sep 25, 2005 | 04:11 PM
  #32
C6.Z51's Avatar
I would do a 408 stroker block with a built bottom end. That should be able to handle some boost. My buddy said he saw a 99 FRC vette with a 408 stroker and nitrous...the car is insane
Old Sep 26, 2005 | 09:56 AM
  #33
like i said........ you can get an iron block out to 427... but it's not going to be the 4.125 bore and 4 inch stroke like the ls-7/c5-r. it will be bored .060 over w/ a 4.125" crank. that's 427 cubes. if that's what you want to do i don't recomend boosting it becuase the cylinder walls start getting thin at .060 over. i've heard of a few boosed .060 over blocks cracking. another thing to think about when boosting it is the rotational mass/weight of the big stroker cranks. if you want to boost it on a budget... you can use an iron block w/ forged internals and a stock crank. SPEEDINC, one of the sponsors, uses a .030 over iron block, stock crank and a single t88 turbo to make nearly 1000 r.w.h.p. they have their t76 kits being used with similar motors, even forged 348 stock alum block motors. they're getting HUGE power out of these combo's with relatively small cams, and relatively small boost with near stock cubic inch motors. they have so far been pretty reliable. give them a call. i think using a stock crank w/ an iron block with a little boost is a very cost effective way of making sick power. just a thought. it seems like you really want to be able to say that you have a 427 though.
Old Sep 26, 2005 | 10:21 AM
  #34
JarrettL's Avatar
A 427 can also be had out of an iron block with a .030" over bore and a 4.185" crank from Lunati. Still not my first choice though.
Old Sep 26, 2005 | 03:31 PM
  #35
MonsterZ28's Avatar
I would like a 427 if i go n/a, but im thinking twin turbo, so if i were to go tt i should get a 6.0 iron block with a 4" crank, but dont bore it? or if i can bore it, how far before its in danger of cracking.
Old Sep 27, 2005 | 08:53 AM
  #36
i'd just stick with the stock bore... that's the cheapest way to go... you're only going to get 6 more cubic inches out of the motor by boring it .030 over (which i wouldn't do much more than that for a boosted motor). so i don't think it's really worth the money to get the block machined for just 6 more cubes. yea you can throw a 4" crank in it and have it be a 402, or if you have it bored .030 over it will be a 408. you can get many quality 402 shortblocks already assembled from one of our vendors. SPEED INC. TSP, SLP, MTI, and a bunch of others have either high compression n/a shortblocks, or low compression FI shortblocks. i would go that route...........
Old Oct 22, 2005 | 01:59 PM
  #37
THE_SUPRA's Avatar
what knid of power do the ls2 blocks support? is it possable to make 1000+ whp on an ls2 block?
Old Oct 23, 2005 | 11:51 PM
  #38
BAD FNZ's Avatar
LPE just did a TT LS2 427 that made 1039rwhp spinning on the dyno , so yes it's possible..
Old Oct 23, 2005 | 11:53 PM
  #39
BAD FNZ's Avatar
Also Mighty Mouse ran a 6.0 iron block until he went lean and blew the pistons, he's now doing a 6.0 LS2 setup being built by W2W, he pushed over 900rwhp and is hoping for more on the LS2!
Old Oct 25, 2005 | 10:05 PM
  #40
Ferocity02's Avatar
6.0L Block bored .060 over with a 4.125" crank = 427ci not 447ci.
Basically you have two options if you want a 427ci motor. Resleeved LS1/2/6 block to 4.125" bore and a 4" stroke crank, which is what I am doing. Or a 6.0L iron block bored .060 over with a 4.125" stroke crank. If I'm not mistaken, boring a 6.0L iron block .060 weakens it enough to where it should not be trusted with high amounts of boost or spray.
Are you wanting N/A or boost or spray?
