C6 ZO6 Top Speed Question
Even on the old set-ups when I would be down 30 or even 40 rwhp to his car, I walk him at high speeds.
He would create a 3 - 5 car lead through 4th gear and I would make up ground, catch him, and put 2 -3 CARS on him in 5th
Now I can emabrass his car with my rwhp aero.
I like the WS6 aggressive hood but I LOVE my aero-dynamic hood
Re-read the post dude; I didn't make it sound anything like that
Also, go to some Aerospace Engineering sites and do some research on aerodynamics
A WS6 hood is a huge crutch at lift speeds compared to a Firehawk/TA/Formula/Camaro hood. Still looks good though
Christopher
Christopher
When I said that the WS6 hood would tear itself off at speeds of over 190 mph, I wasn't saying that it wasn't aerodynamic, but rather that the ram-air is so affective that it pressurizes the engine compartment to such an extent that the hood bulges outward eventually causing it's destruction.
1. The front end is more aerodynamic because of the Camaro's false grill area kind of acts like a chute to a mild degree and
2. The rear fenders are more rounded above and behind the rear tires on T/A's, which helps the air flow smoothly past the car and
3. the rear bumper extends further rearward on T/A's, which helps the fast moving air more easily fill in the vacuum behind the car
None of these differances have been documented by any private testing facility and so no numbers are published. This of course means that anyone is free to disagree and no one can present numbers to refute arguments. These differances are simply professional/educated assumptions based on the results of actual changes made to f-body race cars and the known general affects of differing shapes on aerodynamics.
The horsepower deficit guess I stated was based on the fact that we would do multiple runs from various speeds where he would gain a few cars distance and then I would always make it up and surpass him in 5th.
I know you can understand that if he could put roughly the same amount of cars on me repeatedly in 1st through 4th gears during roll-races that he is making more power than me at the time. I hope you would agree with at least that statement.
THIS IS REAL WORLD DATA
Whether or not he was making 30 to 40 or even as low as 15 to 25 rwhp more than me at the time of multiple testing is unsure and was not dyno-tested . . . but he was making a decent amount more power
Pete from CNC couldn't figure it out either; he's the one that did the Heads on the WS6 in question.
We called MTI as well . . . everyone said that, other than AERODYNAMICS, it had to be gears . . . I have the stock 3:42's and so does he and we both have the same D&D M6 tranny's; process of elimination dude.
Also you are incorrect about the hood ripping off at 190 mph or better; the WS6 hood holds on fine
The only immediate concern at those speeds is, surprisingly, the windshield. It begins to resonate and make a HIGHLY unsettling noise at those velocities.
As I mentioned before about the hp deficit, these runs were done a long time ago and a couple set-ups ago. My set-up is far stronger than his now so we wouldn't have that weird losing in 4th then winning in 5th gear thing now
Only me winning the whole time
Noone's knocking the WS6 hood ---> see sig
<--- but don't think that the extra few square inches of frontal area wouldn't make a dramatic impact in high-speed drag; because it would
Jason
Sorry about that powerful word there hotrod, didn't know you were so sensitive lol !
Whether or not he was making 30 to 40 or even as low as 15 to 25 rwhp more than me at the time of testing is unsure and was not dyno-tested . . . but he was making a decent amount more power
<--- but don't think that the extra few square inches of frontal area wouldn't not make a dramatic impact in drag; because it would
Good night, I'm going to bed now
Thats what I thought. Ive gone 150+ in both my SS and WS6 and they felt the same to me, but thats imo, which is worthless, just like yours. Because you "have NO scientific data", as you stated. If your going to say that the SS spoiler is "worthless", you could at least show some proof, and not your "professional" opnion.
Acually you did, and it seems to be the same thing MTI thought.
Ive done my reasearch, have you? If so you would have known that the WS6 hood dosent increase frontal area.
Id love to see your numbers that say that so you can prove me wrong.
Yes I've done my research and used the incorrect wording . . . as Racehead pointed out, the WS6 hood will degrade and negatively affect the aero-dynamics of the Trans Am
I'll list all of the mods in my car . . . I'm glad somebody gave me an excuse to do so
Christopher's Onyx Black 2001 SLP T/A Firehawk M6 #89
Bilsteins, Chrome Rims, Deck Mat, Birth Certificate, Portfolio
PERFORMANCE: Jung's S2 Heads stock CR | TSP 237/242 MS3 | '03 Viper Tranny | Byun Speed supplied F.A.S.T. LSX 90mm Red Intake Manifold | Kooks 1 7/8”, 3” Y | Spec S3 Kevlar Clutch | SLP Hi-Flow Radiator | Corsa Cat-back with Borla XR1 in the I-pipe | Meziere EWP 160* | LPE 3 1/2" Aluminum Driveshaft | F.A.S.T. 90 mm TB | Racetronix Fuel Pump | De-screened MAF | MTI Clear Lid-K&N | ASP Crank Pulley | TSP LS6 Ported Oil Pump | Rollmaster Double-Roller Timing Chain | TR Pushrods | SLP Bellows | NGK Plugs-MSD'S | Harlan's Shiftlight | FRA | TBB | tuned by Me | Crane Valvetrain with PP .650 lift springs | Hotchkis SFC's & STB | Mac Rear-End Cover with tighter lashed gears | 17x11 rear Firehawk’s with Nitto 315’s | Stock Hurst with UMI Short Stick | SLP Reverse Logic Module | New '04 LS1 engine at 48K mi | Brembo Slotted and Cross-drilled Rotors with Red Calipers.
COSMETIC: BPP Headlights, Granatelli 200 mph White Gauges, Custom Front Air Dam, Custom Firehawk Fuel Rail Covers, Custom Firehawk Headrest Embroidery, Custom Carbon Fiber Interior, Custom Red Leather Interior, Custom Red Carpet, Custom Red Tubing for Engine Bay, Mallory Billet Polished Aluminum Interior, Pioneer 10" Stealth Box, Clear Corner Lenses, Trans Am Valve Stems.
As for my vague comment about rwhp aero . . . I've got a lot more motor then him now and I still have an aero advantage including my headlights now (at night at least)
No video because the WS6 in question was not mine, but his (forged 347 '02 WS6).
Didn't know that about the windows but that is VERY reassuring
As I said before, it was EXTREMELY disconcerting to hear that vibration at those speeds . . . my passenger very nearly took a dump on his seat I'm gonna be uploading a video of my Firehawk going 90 to 190 mph on streetfire's site . . . I think EVERYONE here would appreciate seeing a stock displacement, naturally aspirated LS1 making that run in a FAR shorter time then the Gallardo's video showed
Good reading guys
I only have real-world testing with no sophisticated equipment. Educated guess', again like others here
, based on general knowledge of aerodynamics/drag etc.Cars usually have a problem with lifting at the front as velocity, and wind shear, increases. The more streamlined the car is on top, and the flater it is underneath, the more aerodynamic the car is with down-force suffering proportionally.
This increase in aerodynamic efficency is what allows the car in question to pass through the air more easily.
Please bear with me . . . my memory of college physics/engineering is fading with the years
Any bulge or "nostrils" in this case which take away from the streamling of the vehicle should negatively effect aerodynamics but possibly aid in down-force; again, just guessing here
Ofcourse it's a double-edged sword with aerodynamics and down-force. If the shell is designed for maximum down-force it will be negatively effecting the streamlining aerodynamics. Thus more power will be required to move at higher speeds.
This was the GREATEST dilemma the Engineers at Bugatti faced for the last few YEARS when designing the Veyron.
In the end, the ingenius automatic wing deployment variations for down-force and aerodynamics solved the problem; also automatic suspension played no small part
With the handling setting at speeds below 22x mph, the wing is high and extended to maximize down-force and, thereby, maximizing high-speed handling and stability. Yet it will not exceed speeds higher than this with that particular wing/suspension setting.
With the top-speed setting and attempting maximum velocity, 253 mph, the wing is retracted to almost nothing to increase aerodynamics and the car's ability to displace the air better; thus achieving maximum velocity. Only problem is down-force is dam# near crippled and high-speed stability is hazardous at best.
Sorry about the rambling but I've enjoyed the topic very much
It's been years since I've been able to engage in a theoretical discussion such as this one
If you still have the rubber ones then you'd better install metal ones for high speed work
What is a Trans Am valve stem ?
You need a new passenger
Can't wait to see the vid
http://pontiacmall.com/prodinfo.asp?number=PO146My mis-read on the statement
I agree, the passenger has a ~10.0, 9 sec capable, forged 375" LS1 Z28 that traps above 136 mph yet he was nervous to say the least doing high-speed stuff as a passenger
Sorry Devon . . . you're still my boy
Your experience with competitors at the speeds in question is illuminating . . . it also gives Julian ('02 forged 347 WS6) and I more questions than answers as to why there is such a HUGE discrepancy above 150 mph between our cars
Oh well . . . wish I could get some of the equipment Bugatti used and borrow a GM wind tunnel
I'd much rather come up by you and go all out on the highways in your neck of the woods . . . I'd love to take a spin in that SSC
Ofcourse my DREAM would be to have my car in Germany
Now I just gotta replace this piece of crap Spec with a Textralia . . . SECOND DISC IN LESS THAN 2 YEARS with NO TRACK/VHT LAUNCHES
Young . . . I'll be ordering as soon as I wake up
