C6 ZO6 Top Speed Question
Old Oct 2, 2005 | 04:32 PM
Given To Fly's Avatar
Default C6 ZO6 Top Speed Question
I have the October issue of Car and Driver here and something puzzles me:
Gear Speed in Gears
I 59 mph (7000 rpm)
II 88 mph (7000 rpm)
III 121 mph (7000 rpm)
IV 157 mph (7000 rpm)
V 198 mph (6500 rpm)
VI 160 mph (3600 rpm)
What's with the 6500 rpm in 5th gear? Why don't they use 7000 like the rest of the gears (except 6th)? It seems the top speed would be higher or am I missing something?
Old Oct 2, 2005 | 04:35 PM
ss1129's Avatar
um...I think i was watching the building of the c6 corvette and they hit 180 in a non z06 version. I could be wrong though. I will watch it again.
Old Oct 2, 2005 | 04:40 PM
BlueSix's Avatar
There is a good chance the car simply won't pull past 6500 rpm in 5th.
Old Oct 2, 2005 | 04:42 PM
Ryan02SS's Avatar
More than likely aerodynamics. The Fbody platform becomes aerodynamically dead after 170mph.
Old Oct 2, 2005 | 04:50 PM
John McGraw's Avatar
Blue six is exactly correct. There just ain't enough power left to pull beyond 6500 in 5th. A lot of people just do not understand the relationship between speed and frictional loss associated with it. The frictional loss goes up by the square of the velocity, if all else is equal. If it takes 100 horsepower to make a particular car go 100 mph, it will take 400 hp to make that same car go 200! This is why aerodynamics is so important, if you can lower the CD, you can travel faster without the need for more horsepower.
Regards, John McGraw
Old Oct 2, 2005 | 05:37 PM
gun5l1ng3r's Avatar
So, then how much extra HP would the ZO6 need to break the awesome 200MPH barrier. Are we talking about a set of long tube headers, or a radical cam. I would think that 2 mph could definitley be added to the top speed with just a set of headers or even a computer tune.
Old Oct 2, 2005 | 06:34 PM
Gary Z's Avatar
I think the truth is that the C6 Z06 can exceed 200 MPH without modification.
Old Oct 2, 2005 | 06:58 PM
Wnts2Go10O's Avatar
limiter maybe?
Old Oct 2, 2005 | 08:31 PM
P Mack's Avatar
Originally Posted by John McGraw
Blue six is exactly correct. There just ain't enough power left to pull beyond 6500 in 5th. A lot of people just do not understand the relationship between speed and frictional loss associated with it. The frictional loss goes up by the square of the velocity, if all else is equal. If it takes 25 horsepower to make a particular car go 100 mph, it will take 625 hp to make that same car go 200! This is why aerodynamics is so important, if you can lower the CD, you can travel faster without the need for more horsepower.
You made a couple different math errors there.
Old Oct 2, 2005 | 09:16 PM
P Mack,
You are absolutely correct, I squared the horsepower instead of just multiplying it X 4 ! Duh! Corrected now.
Old Oct 2, 2005 | 09:41 PM
P Mack's Avatar
One more thing, it is force (drag) that is related to velocity^2. Power is a function of velocity^3. For the purpose of this thread, power = drag * velocity.
Old Oct 2, 2005 | 10:10 PM
P Mack,
I knew the Qubeing formula was used in centrifigual fan calculations, but I did not know that it applied here. I allways just thought that it was a simple square of the velocity. So, if I understand you correctly, a 100 hp at 100 mph would be 800 hp at 200mph?
Old Oct 2, 2005 | 10:22 PM
P Mack,
Never mind. After thinking about it, it only makes sense! I was thinking of force (drag), but totally discounting the effects of velocity.
Old Oct 2, 2005 | 10:28 PM
P Mack's Avatar
edit: sorry, I hijacked the thread
Old Oct 2, 2005 | 10:44 PM
Old Oct 2, 2005 | 11:09 PM
P Mack's Avatar
To get back on topic, the reason it only goes to 6500 in fifth is because at 7000 rpm it would be going about 213 mph. And to do that would take roughly 25% more horsepower. Instead of 505 hp at 6500 rpm, it would need around 630 hp at 7000 rpm.
Old Oct 2, 2005 | 11:50 PM
Richiec77's Avatar
Hmmm. With bolt-on, Cam, Headers, tune; it might do that.
Old Oct 3, 2005 | 12:20 AM
BigBronco's Avatar
should be interesting to see what it can do
Old Oct 3, 2005 | 10:06 AM
StickSS's Avatar
Hi All: I think the reason it didn't go over 200 mph is more to do with limitations of the stock ECM and speed sensor. I don't think it is calibrated for over 200 mph operation. If you could recalibrated the ECM and sensor I think you would see a higher top end? Maybe FAST will come out with an aftermarket unit for these motors? Just my thoughts I could be wrong. Bye
Old Oct 3, 2005 | 12:59 PM
Is there some politics involved too? If a car has a claimed top speed of 200 mph or more does something happen? (Insurance, price, etc.) I mean, 198 is so close that it seems Chevy could have made a very minute change to push it over 200, or do they just not care?
