LS7 rocker available
Old Oct 10, 2005 | 12:10 PM
Greg Fell's Avatar
Default LS7 rocker available
12579617 exhaust
12579615 intake
I just ordered them to complete my LS7 heads/manifold/rocker project.
Now I just need to get them in hand (I wonder how long that will be!), find springs, valves and a cam!
Old Oct 10, 2005 | 12:50 PM
WS-Sick's Avatar
What size motor are you running? Looks like you've already got a beast, but nothing is ever fast enough.
Old Oct 10, 2005 | 12:51 PM
Greg Fell's Avatar
4.100 x 4.00 5.3L block 422
Old Oct 10, 2005 | 12:55 PM
jerflash's Avatar
4.1 bore?
how did you get a 5.3 block out that far
Old Oct 10, 2005 | 01:21 PM
Greg Fell's Avatar
It is a resleeved block.
Old Oct 10, 2005 | 02:24 PM
slowgmc's Avatar
is it a cast iron block or aluminum??
Old Oct 10, 2005 | 02:26 PM
Greg Fell's Avatar
it is alum. in 2004 (or maybe 2005) they started offereing a alum version, prior to that it was iron, i believe.
Old Oct 12, 2005 | 04:11 PM
Badls6SS's Avatar
Where Did You Get The Motor At And How Much
Old Oct 12, 2005 | 04:51 PM
Greg Fell's Avatar
My motor is an ARE 422. Not sure what the going rate is. A stroker kit is usually 3kish? A sleeved block is another 3500ish? Plan on 10k.
Old Oct 18, 2005 | 06:15 AM
tdrumm's Avatar
Did you get them yet???
Old Oct 18, 2005 | 08:44 AM
Greg Fell's Avatar
No, just the heads and the manifold
Old Oct 18, 2005 | 01:04 PM
strokedls1's Avatar
What is the pricing for the rockers?
Old Oct 18, 2005 | 01:07 PM
Greg Fell's Avatar
They are like 7.75 each
I got all 16 for $151 to my door.
Old Oct 18, 2005 | 02:51 PM
strokedls1's Avatar
This is a little off this thread, but what is cc of the chamber on those ls7 heads, and what range can they be milled to if you know off hand. They are 11 degree heads correct. Thanks
Old Oct 18, 2005 | 02:58 PM
Greg Fell's Avatar
70cc. I've heard anywhere from .030 to .050 to .1
I think most would agree you could take down to 65-66 cc's and be fine.
They are 12* heads
Old Oct 18, 2005 | 03:06 PM
Camaro_Zach's Avatar
what ratio are the rockers? are they split duration? etc. any/all info is apprecaited!
