recieved LS7 Heads/Manifold
Old Oct 19, 2005 | 12:35 PM
DAPSUPRSLO's Avatar
Originally Posted by Greg Fell
I'm thinking of going TI intake and stainless exhaust.
Rockers are non adjustable.
Or you could just go with a solid roller setup, high spring pressure, and save money over the titanium valve setup. Plus, you could run the kind of lift these heads really want (well, depending on how well your ls7 intake will let them flow). Good luck and get us those flow numbers, i'd love to see how they flow through the ls7 intake.
Old Oct 19, 2005 | 12:47 PM
Greg Fell's Avatar
i'm not sure how much lift i'll be able to run, as my pistons are 15* flycut.
if i ran a solid roller...i'd have to get rockers that are big bucks too. probably wouldn't save anything over the TI/hyd setup.
Old Oct 19, 2005 | 12:56 PM
DAPSUPRSLO's Avatar
You will probably be ok with the lift as peak lift only happens during the time the pistons is at it's farthest or closest to the bottom of the bore. You'd have to keep a close eye on p/v only in the sense that the ramps are much more agressive on the solid (depending on the lobe you choose) and this is where you may run into problems. I would guess that with a 244ish/248ish cam you won't have any contact issues though.
As far as the rockers though I didn't even think about that. You could get a set of T&D's for 800 though. Springs and everything else isn't going to be a huge difference between solid and hydraulic though, unless you've already purchased all the parts.
Then again I keep forgetting that you will only be purchasing the titanium intake valve so it's not like you are going to spend $1600 or anything for those valves so in the long run it may be cheaper for the titanium intake valve.
Old Oct 19, 2005 | 02:28 PM
Ferocity02's Avatar
Have you figured out what valves, springs, and retainers you are going to use? If the valves are the same stem diameter you might be able to get away with using LS1 Ti retainers and some Patriot springs. The springs might need to be shimmed depending on the stem height above the head. Also, what about valve covers?
Old Oct 19, 2005 | 02:36 PM
Greg Fell's Avatar
I thin I'm going to go with TI valves. Craig at ET is providing me a 'kit'.
Not sure about the valve covers, I wondered if they'd have enough height.
Old Oct 19, 2005 | 03:14 PM
Ferocity02's Avatar
Aren't the Ti valves like a grand for a set? Have you even found any stainless valves for the LS7 heads?
Good info, thanks Greg!
Old Oct 19, 2005 | 03:22 PM
Greg Fell's Avatar
The kit is pricey indeed. PM me and I can discuss that with you.
Craig also had stainless valves...or should I say, could get stainless valves. They were cheaper, but they are a huge/long valve. I personally feel that with a hydraulic roller..there will be issues with float/spring pressure etc.
Old Oct 19, 2005 | 03:46 PM
superls1's Avatar
I am trying to educate myself. I have wondered if there would be P/V issues with these heads. However, I thought the piston and valve were actually closer according to something like the attached picture. Of course, the cam specs will vary, but in general is this picture correct? How much does the valve angle differnce impact a setup like this (I guess that is just one of the questions).
Attached Thumbnails recieved LS7 Heads/Manifold-piston_vs_valve.gif
Old Oct 19, 2005 | 05:24 PM
Beast96Z's Avatar
Going to a 11 degree head should provide you with more clearence. ET put a .750" lift solid roller in and checked clearence with their 265"s. It fit fine, and that's a huge cam.
Old Oct 19, 2005 | 06:57 PM
DAPSUPRSLO's Avatar
In general the reduced valve angle head will provide you with added clearence, given the same valve centerline (location of the valve center in relation to the center of the bore); however, because you are talking about a 2.20" intake valve verses the stock 2.00" or popular aftermarket 2.02 to 2.08 sizes of a typical ls1 the clearence gained by the valve angle is probably negated cause of the huge intake valve of the ls7 head.
