when could i expect to be able to buy a ls7 bare block?
Old May 16, 2006 | 11:18 AM
Drewman's Avatar
Originally Posted by Billiumss
It's been 6 months since I asked last, when will GM release this LS7 block to the general public?
It's listed at GM parts direct. All of the LS7 parts I've ordered through them have arrived within ~ a 6 week window.
http://www.gmpartsdirect.com/results...umber=17802854
Old May 16, 2006 | 11:45 AM
BlueSix's Avatar
Hey guys, just get an LS2 block and get it re-sleeved....that's all the LS7 is anyway.
Old May 16, 2006 | 12:22 PM
Billiumss's Avatar
Costs more $$$$, that's why I'm interested in the LS7 block...
Old May 16, 2006 | 12:24 PM
Drewman's Avatar
Nope. Not for now anyways. A resleeved block is ~$3300 from Rapid Motorsports. That GM Parts Direct link is $3K and change for the block + $680 S&H.
Old May 16, 2006 | 12:52 PM
LSxChevelle's Avatar
There is a non sponsor (dealership) selling them for ~$3050 + shipping.
Old May 17, 2006 | 12:37 AM
BlueSix's Avatar
It's the same thing. And a sleeved LS2 will be stronger.
Old May 17, 2006 | 02:21 AM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default LS2 sleeved blocks
The LS2 and LS7 blocks are nearly identical as far as the casting goes. The main differences are lack of drilled holes in the bosses for displacement on demand in the LS7 and steel main caps instead of powdered metal as on the LS2 and all earlier LS blocks. The standard LS2 main caps are more than adequate for most build ups however. The LS7 uses the same torque turn main cap fasteners as the LS2.
Darton has two sleeves we designed together for the LS2 block. The first is the LS2 large bore sleeve. This sleeve is designed for 4.125" bore and has sufficient wall thickness to go to 4.155" max. bore. The sleeve has a large flange diameter to provide a robust flange seating surface to prevent the sleeve from sinking. Sleeve material is the same high strength ductile iron as used in their top fuel - funny car sleeves.
The second sleeve is the one I use most often. This is the LS7 replacement sleeve available as a custom order sleeve only. I usually keep at least one set on hand. This sleeve is also designed for 4.125" bore but is thick enough to go all the way to 4.190" bore normally aspirated.
Both styles of sleeves have been made longer, for strokes up to 4.250".
Pricing is very competitive compared to the LS7 factory block. You end up with a stronger cylinder wall capable of going larger in bore size to boot.
These blocks need to be sleeved on CNC machines with flood coolant as I have always emphasized in the past. Brand new blocks must be stress relieved. This applies to any new casting whether you have it resleeved or not.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old May 17, 2006 | 11:22 AM
Magnus's Avatar
LS1TECH Sponsor
Thanks for the info Steve!
Old May 17, 2006 | 11:51 AM
disco192's Avatar
So are you saying you can expect 469 cubic inch LSx motors?
wow!
Old May 17, 2006 | 04:44 PM
LS1TECH Sponsor
Default 469 inch LS2 - LS7
That's what I'm saying.
The MID sleeves will go slightly larger, 4.200" bore for 471 cubic inches. Darton is working on MID sleeves for the LS2 block but has 4.200" capable MID sleeves in stock for the LS1.
Steve
wow!
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Old May 19, 2006 | 08:20 AM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
Ok, everyone, here is what you have been waiting for. We got our first shipment of LS7 blocks in. They are ones that were pre sold but know is the time to put in your order because they are starting to ship. Who will be next in line??????????? $3175.00 plus shipping...................
Brian (806) 798-4000 ext 354
Old May 19, 2006 | 10:26 PM
  #32
69firebird's Avatar
brain
can you get the L-92 heads?
Thanks
ed
firebird455@gmail.com
