Any LS2 build ups and done.please check
Old Nov 28, 2005 | 09:31 PM
A Mustang's NightMare's Avatar
Default Any LS2 build ups and done.please check
My car has being done about 3 weeks ago.
My RPM's dont work and I'm having a hard time starting it.
Have any of you guys encounter the same. thanks
Old Nov 30, 2005 | 06:21 PM
hpcubed's Avatar
Do you have the crank sensor connected? Where did you buy it?
Old Nov 30, 2005 | 06:27 PM
Beast96Z's Avatar
Probablly spliced the wires wrong going to your cam position sensor.
Old Nov 30, 2005 | 08:46 PM
Black8Banger's Avatar
ok why wont it started...i battled with this for over 2 weeks with my 402, there are a hundred things it could be
for me it was a ground wire not properly connected to the back of the head
Old Dec 1, 2005 | 09:46 AM
DrkPhx's Avatar
ALmost positive it's the cam sensor improperly wired.
Old Dec 1, 2005 | 10:02 AM
My bad the car starts.But sometimes it just cranks, and after a few times cranking it starts.
The Crank sensor is connected. I'm going to re doo all the wires I spliced.
Since I only splice the cam, crank, Right o2 sensors. I think the only one of those 3 for the RPM'S would be the crank sensor right?
and for the hard start, either bouth the cam , crank, o2 sensor or all 3
Old Dec 1, 2005 | 10:08 AM
did any of you guys splice the wires?
Thanks for the help guys
Old Dec 1, 2005 | 10:24 AM
DrkPhx's Avatar
Why did you splice the crank wire? That should be fine. I spliced the cam sensor wire, but now there are true plug n play harnesses for that. What codes are you getting?
Old Dec 1, 2005 | 12:56 PM
ONEBADWS6's Avatar
the ground wires on the back of the head were a big problem for me, check those, then check them again.
Old Dec 1, 2005 | 04:46 PM
I will check all the ground wires also. I splice the crank wires, because I wanted all the wires to run truogh the front and under engine mount away from the header.
I forst use my friends scanner, but only the cam sensor came up.At that time I was running with a different problem.I fix that allready
today I use the Snap On scanner.Came with 9 codes, o2 sensors, cam sensor are the critical ones.
Old Dec 1, 2005 | 04:48 PM
I'm sure the ground wires are ok, but I'm still going to check them all
Old Dec 1, 2005 | 05:10 PM
hpcubed's Avatar
Sounds more like the cam sensor wire. I think the cam sensor aids mostly in quicker more efficient startup. Also I have read that the two outside wires are switched for the LS2.
Old Dec 1, 2005 | 05:11 PM
hpcubed's Avatar
Sounds more like the cam sensor wire. I think the cam sensor aids mostly in quicker more efficient startup. Also I have read that the two outside wires are switched when going from LS1 harness to LS2.
Old Dec 1, 2005 | 11:23 PM
HP cubed were did you read that.If thats the case than I will try it. Hope that would be it. Thanks
Old Dec 2, 2005 | 08:19 AM
DrkPhx's Avatar
Do a search in this forum and you will find a couple threads discussing this.
Are you getting any cam sensor codes? You really need to check.
Old Dec 2, 2005 | 09:59 AM
Yea one of the 9 codes was the cam sensor.HP cubed was right the red and brown wires are switched.I fix that allready, I will let you guys know the outcome. Thanks
Old Dec 11, 2005 | 02:29 AM
Ok the I finally fixed the problem.Bad cam sensor,the thing that tru me off was that I had a new cam sensor from the begining. So I just order a new one replace it and it works.
For any one that runs into the same problem.
1. The cam sensor has plus on the right, ground in the middle and the signal on the left.This marks are shown inside the plug of the sensor.Red of course is power, Pink is ground, and brown is signal.
2.make shore you dont cross the red wire to the left side of the sensor
3. make shore you have a good connection in your wires.
Old Dec 11, 2005 | 09:45 AM
Grimes's Avatar
glad to see it worked out. I was unaware that the pin-outs change in the ls2
Old Dec 12, 2005 | 02:28 AM
Thanks to every one that gave me there advise
