LS7 induction on LS1 long block?
Old Nov 30, 2005 | 12:16 PM
jdeuel87's Avatar
Default LS7 induction on LS1 long block?
I am in the position to use a complete LS7 induction system [intake, throttle body, injectors, etc] and coil packs that a friend is taking off a new crate engine. Can I use these on my LS1 long block [2000 camaro]? Do i need to any modifications? THANKS
Old Nov 30, 2005 | 01:50 PM
Nasty N8's Avatar
The heads are totaly different ports you would need LS7 heads. You could use an LS2 intake or LSX and that TB only if you have a drive by wire now.
nate
Old Nov 30, 2005 | 07:49 PM
ChucksZ06's Avatar
I think you can. injectors and throttle body fitting would take a little work. There might be slight deck ht difference but you ought to port match heads and intake anyway. your low end would suffer but would scream up top with a good cam and exhaust.
ChucksZ06's Avatar
My bad...I thought you had the heads also...Nasty is correct.
