Progress pics of BAD 53 - C5 LS7 transplant
Old Dec 12, 2005 | 07:33 PM
98blackSS's Avatar
Default Progress pics of BAD 53 - C5 LS7 transplant
Here's a few pics of what we got accomplished this past weekend. Sorry for the large size.
Fresh off the truck
Pic of her nekkid
Comparison of LS7 and new LS2 cam sprockets
Misc conversion parts needed to run with the LS1 PCM
C5 cradle placed under LS7 for fit checks
Another angle of the cradle
And yet another.. with steering rack
Shot of the bores
LS7 Pistons
24x reluctor wheel swap
Comparison to the original wheel
Table of parts
Teaser shot with a Kook's 1 7/8" header strapped on
More to come..
Old Dec 13, 2005 | 10:25 AM
MaximusPrime's Avatar
Awesome!
So you are going to run it off the stock LS1 PCM?
Any other tough obstacles you are going through in the LS7 conversion?
That's badass.
Old Dec 13, 2005 | 11:06 AM
Zach@Texas-Speed's Avatar
Awesome!! Glad to see the long awaited Kooks stuff will be put to great use! Let us know progress of the buildup.
-Zach
Old Dec 13, 2005 | 11:12 AM
chupr0kabra's Avatar
Sofa king jealous!
-Mike
Old Dec 13, 2005 | 01:06 PM
John B's Avatar
Moderator
You've made outstnding progress! I'm lmost ready to think twice about changing my 58x reluctor too. What is you plan for the dry sump? I just got one of the OEM lines in the mail yesterday and plan to use just the fittings and make new hoses going to a Peterson Fluid Systems tank.
Old Dec 13, 2005 | 01:12 PM
hokie's Avatar
Tom is the man. Can't wait to get a cam and get that thing back together. It's going to be a beast.
Old Dec 13, 2005 | 05:08 PM
Bill Reid's Avatar
Hell ya... looks bitchin' Tom!
Bill
Old Dec 13, 2005 | 06:37 PM
Bill's 02 Z-28 SS's Avatar
Hi
how did you change the reluctor wheel? did you do it or did you have somebody do it for you? I would like know how you go about doing it.
Bill
Old Dec 13, 2005 | 07:49 PM
98blackSS's Avatar
Thanks guys. The reluctor swap wasn't that bad. We pulled the crank, removed the old wheel and heated up the new one in an oven and slid it over the crank while using the goodson alignment tool to verify it was placed exactly where it should be..
There's still some unknowns with using the LS1 PCM, and I'm sure we're not out of the woods yet with this - hopefully we'll be able to get her running and tuned though. We'll be running a stg2 cam so that should make tuning even more fun.. heh.
We plan on running the dry sump afterall. We have the tank and lines already and will most likely mount it where the batt was - with some modification of course. The PCM will most likely have to be moved over a bit as well I think. The stock lines will probably need to be modified for length. We hope to find out next week when we get back over to the garage. There's only two of us working on the project and we only get over there when we both have free time so it gets frustrating at times. We're both very anxious to get it done
It's been quite a learning experience to date, but certainly a fun project. Mark and I couldn't be where we're at with it though without the expertise of some of the forum members here, particularly Bill Reid's, John B's and Scott's helpful tips and recommendations.. Thanks again guys!
Old Dec 13, 2005 | 11:35 PM
xxxhp's Avatar
Good luck with the project. Were there any issues with fitting your Kooks 1 7/8" headers on the LS7 heads?
Old Dec 14, 2005 | 12:01 AM
Ferocity02's Avatar
Very impressive! It looks like its a nearly direct swap. Keep us updated!
Old Dec 14, 2005 | 11:10 AM
Race-Prep's Avatar
Suspended Sponsor
Just a quick fact, the LS1 reluctor wheel is also a counterweight and needs to be the right weight or your balance will be off, I recommend you get the rotating assy re-balanced or you will likely have a balance issue as your new wheel is not drilled like the one you replaced, notice the square holes, it may not be much but it could give you trouble, better safe than sorry.
-Bryan
Old Dec 19, 2005 | 08:39 PM
blackraven's Avatar
I agree with Race-Prep It doesn't cost that much to rebalance your crank and there is enough weight difference in the reluctor wheels that it could cause some issues.
Old Dec 20, 2005 | 03:15 PM
Mitzelj's Avatar
While the weight might be slightly different, I can't imagine it to be more than a few grams and since it's close to the centerline of crank and it does not reciprocate, I'm not sure I'd worry about it. But I think I'd weigh em to be sure. Just my 2 cents and as always YMMV. Jeff
Old Dec 23, 2005 | 08:47 PM
98blackSS's Avatar
Welp, until we get a hookup from someone inside GM, the project will be on hold indefinitely. We cannot get the bolts for the LS7 rods through our normal parts distributor. We even have the P/N for them, but GM isn't releasing the bolts for some reason.
these are the only parts holding up the entire project..
If anyone has a hookup at GM, please PM me - hint Katech
Old Dec 23, 2005 | 09:22 PM
Bill Reid's Avatar
me too
Old Dec 24, 2005 | 08:37 AM
Builder's Avatar
Got my ear to the ground on these bolts...
-- Scott
Old Dec 24, 2005 | 11:24 AM
98blackSS's Avatar
Thanks guys. I'd really like to go with some stronger ARP or Katech's, but I'd take the stockers right now just to get this project back on track again.. Hopefully Jason will come back with some good news too if he reads the post.
I appreciate everyones help and wish everyone a safe holiday!
Old Dec 29, 2005 | 05:07 AM
bluecamaroz28's Avatar
So sexy.
Old Dec 31, 2005 | 09:26 AM
98blackSS's Avatar
Just an update.. We received our LS7 cam and springs from HPE yesterday.
Also received our C6 Z06 brakes from Gene at Fred Beans.
Brake pics:
http://filebox.vt.edu/users/mkoch/PDRM0001.JPG
http://filebox.vt.edu/users/mkoch/PDRM0002.JPG
http://filebox.vt.edu/users/mkoch/PDRM0003.JPG
http://filebox.vt.edu/users/mkoch/PDRM0004.JPG
http://filebox.vt.edu/users/mkoch/PDRM0005.JPG
http://filebox.vt.edu/users/mkoch/PDRM0006.JPG
Couple pics of the DTE 3.90 rear and DTE brace assembled:
http://filebox.vt.edu/users/mkoch/PDRM0007.JPG
http://filebox.vt.edu/users/mkoch/PDRM0008.JPG
