Pellets in LS2 crate coolant passages
Old Dec 20, 2005 | 08:55 AM
jpolser's Avatar
Default Pellets in LS2 crate coolant passages
I assumed that since these were there I should leave them.
There is a pellet (looks like a round vitamin or something) behind each side of the water pump and one inside the pump.
Assuming these need to stay there for initial startup, what are they for?
Old Dec 20, 2005 | 09:00 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Sounds like GM coolant system sealer pellets. I thought they had to be broken up and dissolved though. Maybe they dissolve during normal operation.
Old Dec 20, 2005 | 09:02 AM
jpolser's Avatar
Do you know how long engines have coolant in them before they are started for the first time (on the vehicle assembly line)? I could see how sitting in water might disolve them after a while.
Old Dec 20, 2005 | 09:07 AM
LS1TECH Sponsor
I don't know but I'm sure it varies a lot. I wouldn't think the pellets would dissolve unless there was coolant circulation.
Old Dec 20, 2005 | 09:50 AM
slow trap's Avatar
those pellets work wonders for small coolant leaks!
