05 ls2, put in a high volume pump?
Old Jan 1, 2006 | 10:05 AM
poloz28's Avatar
Default 05 ls2, put in a high volume pump?
i have a high volume pump on an ls1, should i replace the 3000 mile ls2 pump or leave it?
Old Jan 2, 2006 | 06:48 AM
GEORGELS7SSR's Avatar
Smile Oil Pressure
your best bet is to leave it alone,the clearances in the engine do not require high oil pressure.
also high oil pressure takes away horsepower
Old Jan 2, 2006 | 12:36 PM
Bill's 02 Z-28 SS's Avatar
Hi George
I would not worry about HP but saving an engine - a good rule is 10lbs per 1K RPMs, so if you plan on cranking 6-7K, you need at least 70lbs.
Happy New Year - Everybody.
Bill
