LS2/7 wiring harness???
Old Jan 8, 2006 | 08:47 PM
NJSPDER's Avatar
Default LS2/7 wiring harness???
i was wondering if the crate LS2 or LS7 can be run using a 99 f-body LS1 harness and computer without major complications?
i know they both come set up for fly by wire, which i would have to convert, but other than that what woudl i need to change?
-thanks
Old Jan 8, 2006 | 08:54 PM
98Z28CobraKiller's Avatar
Restricted User
Yes it can. You will just need to get the extensions for the relocated knock and cam sensors from SPDC. If you have EGR, you will have to delete unless you use the old exhaust and intake.
Old Jan 8, 2006 | 09:45 PM
NJSPDER's Avatar
thanks for the advice.
