Katech-built LS7 makes 655hp 579ft/lbs NA!
just need you to sell it as a creat motor now!!!
Chris.
We do have a crate motor with this setup we will be announcing soon.
Could you guys build a LS7 engine that makes the kind of power you showed on this post (or more) that could rev safely to 8000rpm? Maybe with some aftermarket valve train parts, a new high rpm balanced rotating assembly for the bottom, what ever you need.
I was actually looking at this block to base the engine off of:
https://ls1tech.com/forums/showpost....6&postcount=37
Can you make this engine rev to 8000rpm and make good power over the whole rpm range?
For comparisons sake, a stock lt1 spinning 7000 rpm (which is pretty much spinning it's ***** off) is only at ~110 ft/sec.
Not only is your piston velocity higher ( > 35% higher), but your piston acceleration at TDC/BDC is tremendously higher as well. Rod caps/bolts need to be STRONG. Wrist pins need to be thick and beefy.
Not saying it can't be done, or isn't done, it's just that if/when it happens, it will be a thing of beauty.
Go Katech!! LOL
By the way, are those numbers at the crank or rear wheels?
Go Katech!! LOL
Piston speed is already 4700 ft/sec @7000. I'm sure it could be done, but it would take some engineering and I don't know if those costs would prove much of a benefit.
I would assume that buying a crate motor would be wastefull if you have to replace most or all of the internals of the engine. would it be better to start out with an aftermarket block like the world one in my first post. then add the high end aftermarket stuff. i'm sure it can be done, but at what cost, and how would it effect reliability?
If one were to use theWarhawk LS7X block with it's 0.100 thick liners, you could increase the bore diameter to 4.1850 inches. Add a Callies Magnum XL 3.880 inch stroke lightweight crank, and 6.125 inch Titanium rods, with ARP 3.5 7/16 inch rod bolts.
That would decrease your piston speed, crank angle, side thrust on the piston skirt and cylinder walls, and you would still have a 427 cubic inch motor.
Add the Warhawk LS7X 12 degrees heads with 2.20 inch Titaninum intake valves, 1.625 inch hollow-stem, sodium-filled exhaust valves, 1.625 inch dual valve springs, Titanium retainers, etc.
Pick your intake and throttle body and a solid roller cam and kit and you would be on your way to 8,000 rpms.
Dan
https://ls1tech.com/forums/advanced-engineering-tech/437306-can-you-build-8-000-rpm-ls7.html
2) The Callies crank is $2,700.
3) Callies Comp Star rods with ARP 2000 bolts are $ 600.
4) J.E. Pistons, Pins, and Rings are $1,800
5) A Crane cam and kit $1,000
6) GM Rocker arms $130
7) Crane dual roller timing chain and gear set $207
8) GM LS7 roller lifters $ 91
9) Katech blueprinted LS7 oil pump $175
10) Warhawk bare heads $1,600
11) GM Titanium intake valves $ 465
12) GM LS7 exhaust valves $240
13) GM LS7 intake manifold $ 265
14) Racetronix-Delphi 50 lb injectors $ 440
15) GM LS7 throttle body $ 225
16) Cometic head gaskets $175
17) ARP cylinder head studs $ 220
18) Clevite rod and main bearings $175
That's $9,733.
Add assembly, balancing, and miscellaneous parts - TBD
It certainly would seem doable for less than $20,000.
Both drivers were impressed with the power of the car and can't wait to get to the track again. We are going to be doing some more testing on the LS7, so it should be interesting to see what we can get out of it. Hummmm, maybe some I.R.'s would be sweet!!!
http://bbs.off-road.com/photobb/show...89560/size/big Herman Motorsports
http://bbs.off-road.com/photobb/show...89557/size/big Kash Vessels
Never mess with a good thing, GM tests all this stuff for incredible amounts of time. Why develope new parts when it just isn't neccessary.
https://ls1tech.com/forums/generation-iv-internal-engine/325495-ls2-ls7-gm-parts-numbers-list.html
