Katech-built LS7 makes 655hp 579ft/lbs NA!
...more to come as other camshafts are tested.
http://www.katechengines.com
http://www.umiracing.com
I have a few questions about the data shown on the dyno sheet:
1) How do you maintain 121 to 125 degree F oil temperature?
2) Why did you hold the oil temperature so low when you would make better power if the oil temp were in the 180 to 200 degree F range?
3) Why is the oil pressure so high?
4) What octane fuel was used for this dyno run?
Oil Temp - Temp was not reading.
Oil Pressure - We are running 15W-50 Mobil. Plus, these things have high pressure to begin. It is not uncommon to see 75-90 lbs at idle cold with this oil.
Sunoco 110
I wonder if this is a restriction, or simply as much as this camshaft allows.
For the intake, mentions something about a throttle body. Is it a 8 runner IR intake or the LS7 intake mani?
1 3/4" to 1 7/8" step sounds great.
My guess is this is still a hydraulic roller camshaft with high but not very high duration numbers, IE - prolly 235-240@.05" on the intake side.
700HP will prolly be crossed with the LS7 intake.
Anyone flown a LS7 intake by itself? With the heads?
The 575 TQ extrapolates to 505rwtq 6speed. Will we see more? 530-540rwtq?
Thats a production LS7 intake with UMI TB.
The guys at UMI were very cool to talk to on the phone last week.
