Computer options to control 58x LS2..
Is there a thread somewhere that details your plans for the build? I'm curious to see what parts you are choosing and what power levels you're after.
Stage one of the project will be semi-mild..
LS2
AFR Stage II heads
Comp 230/232 .592/.595 114+2 LSA campshaft
hardened pushrods
ATS oil pan
LS2 throttle body
LS6 or FAST intake (depending on the dyno numbers)
Custom Long Tube Stepped Headers
Later on I might bolt on a magnacharger.
T/56 trans
6-piston Wilwood brakes and all the standard goodies.
LS2 computer hasn't been cracked yet..
Isn't LS2 edit out now???
Xtreme Motorsports in Pheonix/Tempe AZ swaps the crank reluctor when putting them into earlier cars. Might talk to them. You can talk to Chad about it at 480-517-4969. Should be no big deal if you are going to have it apart anyway.
Good luck, Ed
Good luck, Ed
I was going to swap the oil pan, but not mess with pulling the crank, the swap seems like a better idea in the long run. Thanks for the number to Xtreme, I will give them a call.
