LS7 in a 98 Z28
Here is what I think you will need... assuming you will stick with existing 24x reluctor wheel based tuning setup:
1) LS7 pan adaptors and custom oil lines
2) Custom 2 gallon oil tank
3) 24x reluctor wheel installed on crank
4) Early style (1X) LS2 cam sprocket
5) LS1/LS2 cam sensor adaptor harness
6) LS1/LS2 knock sensor adaptor harness
7) Injector adaptor pigtails or splice in new connectors
8) Extend MAP sensor and Fuel Vapor return solenoid wiring to new locations
9) 90MM cable style throttle body... that will fit on the LS7 intake.
10) Custom made (doesn't exist yet) harmonic balancer OR complete custom accessory drive brackets. LS7 Harmonic balancer WILL NOT line up with F-Body acc. drive.
11) Retro LS7 fuel rail for return (in your case)
12) In-tank fuel pump upgrade
And if you are gonna spend the coin on the motor... probably set a bit aside for a header back upgrade that will allow the motor to breath.
I may be missing a few details but I think that about covers it...
Bill
Are you saying that my current exhaust sustem will not work? I am not sure I want to go through all the pain for the conversion that will be necessary?
I might be better of going with an LS2 based big cube motor. I will have about $20,000 total to invest.
I also need to overhaul or replace my L60E transmission, so I am just thinking about which route to go
My father died last year and he had a large farm, 900 acres to be exact. My mother and I are selling a couple hundred acres for a substantail amount. My wife and I will be able to get totaly out of debt, and have a large amount of money left over. After we donate some to the Church and start her new house, I told her all I wanted was 20 grand to put into my car. She wants me to by a new one, but she doesn't unerstand MY investment in the Z28, though I might would look at a 2008 Z28. We feel fortunate to be able to do this. She and I have worked hard and are putting two kids through college. We figure we can spend a little on ourselves!
If you do most of the foot work and are pretty good with a wrench I think you could do the retrofit for under $20k.
Good Luck,
Bill
Good Luck,
Bill
I am not sure what I am going to do right now, but I am going check around. and see what comes up. I may actually buy another car to drive so I can work on this one. Like you said, It will be a good project. My 17 year old son sure thinks so.
If one were to get a BS3 box to control the engine, how many items above would be nixed? #3-#7?
Also, could the F-Body accessories be spaced forward to align with the LS7 balancer/crank pulley or is that going the wrong way?
EDIT. Looking at the accessories, wouldn't the vette stuff fit in an F-body if you relocate the alternator? Like maybe put it over on the top passenger side (PTK has a relocation kit)?
That gets you 500hp to start with... add in 1 to 2k for upgrading the valvetrain cause it is so damn new.... so 14k for a 600 to 650hp power plant now add on wiring, new exhaust (ls1 headers may not match up to the exhaust of the LS7 heads). That is a large chunk of the 20k you had set aside for upgrades... but if gives you bragging rights...
-vs-
Custom built LS2 in 402 or 408 setup (SLP/Lunati/who ever) shortblock for around 3 to 4k then pair it up with ET's new Baby LS7 heads and a high end valve train... you should easily surpase the LS7's stock 500hp and the new ET heads will allow you to use your existing LS1 style headers (if you have a set). They retain the stock LS1 exhaust ports. Add in a LS7 manifold. Looking at about 8 to 10k for a built up setup but probably well above 500hp with the right valvetrain.
Or wait on the L92 motors to become available... GM's got some good parts coming down the pipe in that setup.
Shoot I'ld really suggest waiting for a L92 with a low profile mainfold and a beefed up valvetrain...
This would get you cool things like Displacement on Demand and Variable Valve timing.
That should increased Gas mileage while daily driving along with all the performance increases.
I wounder if GM will offer a retro fit for the computer (maybe painless wiring will put a kit out to retro the L92/L72 module into older cars).
Best bet take a look at the parts available and put together a total package that offers the best bang for the buck for the amount you plan on spending.
Don't forget to look into upgrading the suspension, brakes, and a roll cage (if you're looking for that kind of power I can not stress enough the importance of safety).
-vs-
go with a 4l80e or 400 trans with overdrive kit to hold all that power.
and if yah have enough left over. get a supercharger! looks like you already have everything else!
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
It will be removed if you do not do it yourself, there is a section in a thread somewhere where someone is resizing sig pics for people. Multimedia? User support? I can't remember.
As for the ls7, its a good project if you are starting from scratch, but its not logical if you already have an LS based setup. All the good advice has already been posted
I have decided not to pursue the LS7 issue. If I keep the Z28 I will probably go the 402 route.
