Will an LS2 water pump work on a LS1/LS6?
Old Feb 4, 2006 | 09:04 AM
JimMueller's Avatar
Default Will an LS2 water pump work on a LS1/LS6?
Just as the title says...if not, why not? If yes, what else, if anything, is needed?
Old Feb 4, 2006 | 10:39 AM
bigredexpress99's Avatar
Default yep
Well, when comparing a 2002 corvette ls6 water pump part number to the 2006 gto ls2 part number they are the same. So I would say that they will interchange without any other things being needed to make them work. This is straight from my GM catalog here at work... BTW part number for GM/ACDelco is 89017593. Lists out retail at 305.95. Cost to dealership is 152.96. GM must make it out of gold......
Old Feb 4, 2006 | 11:15 AM
John B's Avatar
Moderator
My LS1/6 waterpump bolts up to my LS7 and I believe the LS2 and LS7 share the same waterpump so the answer is yes! You may want to check the belt tensioner distance. I noticed that the LS7 waterpump has the bosses for the tensioner about 0.070" closer to the block.
Old Feb 4, 2006 | 12:26 PM
Dave_62's Avatar
I have an LS2 pump and a 1999 LS1 pump. They are the same functionally except for the tensioner mount bosses being .115" closer to the block on the LS2 pump. Like the commercial says, your mileage may vary. You'd need to check the pump you take off and make adjustments accordingly.
