LS7 Head Aftermarket Valves
Old Feb 5, 2006 | 10:26 AM
proautoman's Avatar
Default LS7 Head Aftermarket Valves
Any one know if they are available- Need to be 8mm ??
Old Feb 5, 2006 | 01:07 PM
Greg Fell's Avatar
Not yet, from the searching I've done. Supposedly soon however.
You could change from the 8mm guides, and then your options are greater.
Old Feb 5, 2006 | 01:58 PM
proautoman's Avatar
I talked to REV in Florida they said they are working on it. Not done yet
check back in a week or so! They also mentined cutting down 11/32 to 8mm
Any thoughts ??????????
Old Feb 5, 2006 | 02:05 PM
Greg Fell's Avatar
Were these for stainless, or TI?
Cutting down the 11/32 to 8 mm...hmmm I dunno about that. May work fine, but ?
Old Feb 5, 2006 | 08:54 PM
LOnSLO's Avatar
Why don't you guys just change to 5/16 valve guides? Then just order up the valves from wherever.
Old Feb 5, 2006 | 09:54 PM
proautoman's Avatar
stainless
Old Feb 6, 2006 | 01:00 AM
Bring the Noise's Avatar
Page 36 of Ferrea's 2006 catalog shows 4 blanks with an 8 mm diam (2 for intake and 2 for exhaust).
Not sure if they will be large enough but here's the spec's from the pdf.
Part Nº - Type - Head Diam. - Stem Diam. - Overall Length - Tip Length - References
F1443P - E - 36.75 mm - 8mm - 110 mm - 8.5 mm - 12º Super Flo. Special Alloy
F1182P - E - 41 mm - 8mm - 135 mm - BLANK - 15º Super Flo. Finished. No groove. Special Alloy
F1442P - I - 44 mm - 8mm - 110 mm - 8.5 mm - 10º Super Flo. Special Alloy
F1192P - I - 48 mm - 8mm - 135 mm - BLANK - 26º Super Flo. Finished. No Groove. Special Alloy
