Which one and why?
Old Feb 7, 2006 | 07:04 PM
thinkBIG's Avatar
Default Which one and why?
http://www.rapidmotorsports.com/mode...=2&intYearId=3
Rapid Dominator Series 402CI LS2 Crate Engine
Part No: RM-LS2402CR
Price: $10,595.00
This engine made 553 rear wheel horsepower and 490 lbs/ft of rear wheel torque on pump gas! That's approximately 620 hp at the flywheel!
Built in-house by Rapid Motorsports. We use a new LS2 GM aluminum block and provide all the conversions necessary to retrofit any LS1 engine. We take pride in our engines and use the finest parts available. Fully Assembled Crate Motors are manufactured to the highest standards and include only the highest quality components. Our assemblies are lined honed square decked. All clearances meticulously checked and camshaft degreed.
New GM 6.0L LS2 Aluminum Block
Callies Racemaster Forged Crankshaft - 4.000"
Scat Connecting Rods
Diamond Pistons with -2cc or -15cc valve reliefs
Akerly and Albert Ring Set Plasma Moly
Clevite H Series Race Bearings
ARP 2000 Rod Bolts
ARP Main Studs
Rotating Assembly Fully Balanced
Engine Blueprinted
Rapid "Dominator" series Custom Hydraulic Roller Camshaft
JP Dual Roller Chain with Torrington Bearing
Airflow Research 225 Cylinder Heads
Resurface Heads to Desired Compression
ARP Head Studs
Cometic MLS Head Gasket Set
Custom Length Moly Pushrods
New GM OEM Rocker Arm Set
Comp Cams 850-16 Hydraulic Roller Lifters
No Engine Core Required
Does not include intake manifold, windage tray, oil pan or rear cover
Upgrade to Morel Lifters add +$300
OR
http://www.w2wpowertrain.com/pc-77-7...lock-plus.aspx
402 LS2 long block Plus
Our 402 cubic inch long block plus features the same parts as our 402 long block with the addition of
F-body oil pan
F-body front
F-body rear cover
F-body valley pan
F-body damper and crank position sensor
Long block hard parts include
Race prepped LS2 engine block
Callies 4" stroke 4340 forged crankshaft
Callies "Compstar" 6.125" forged connecting rods
Mahle 4" bore forged piston
Clevite, and Federal Mogul bearings
Factory CNC ported cylinder head by ET performance
Matching springs with titanium retainers
Wheel to Wheel custom hydraulic roller camshaft
LS2 Timing chain and hardware
Long blocks are assembled with all quality parts and our painstaking attention to detail to provide a strong, reliable combination.
With proper intake, fuel system, and tune our long block is designed to make 550 horsepower
$9,349
Old Feb 7, 2006 | 07:30 PM
98Z28CobraKiller's Avatar
Restricted User
They both seem a little high.
Old Feb 7, 2006 | 07:56 PM
LPE SS's Avatar
What do you want? Street? Strip? Dyno queen?
Old Feb 8, 2006 | 05:15 AM
thinkBIG's Avatar
Street/Strip.
Old Feb 8, 2006 | 08:42 AM
Florian's Avatar
having the W2W engine installed later this year.....they are a top notch company with a very reputable history.
F
Old Feb 8, 2006 | 12:39 PM
Beast96Z's Avatar
Basically depends on which heads and what rods you want. You can have either package altered to get whatever you want. Both are great companies, but Rapid has always seemed a little high on there pricing compared to others.
Old Feb 8, 2006 | 12:47 PM
Kevin@W2W's Avatar
LS1TECH Sponsor
For clarification purposes our crate engines now use the new Dart cylinder head. Our site will be updated.
The parts cost alone is what produces a higher selling price than other offerings. We are very strict on what parts we use and all prospective parts go though a very strict testing process before we decide what to use.
Thank you for the interest.
Old Feb 8, 2006 | 12:58 PM
chuntington101's Avatar
so what do you think is the limit of both N/A on pump gas? and what options to get there?????
Chris.
Old Feb 8, 2006 | 01:05 PM
Kevin@W2W's Avatar
LS1TECH Sponsor
Chris.
Hey Chris. You getting our twin Rotrex kit yet?
Here is a dyno graph of our carb turn key version running on pump gas. Our standard corrected figures have shown almost 580 hp.
http://w2wpowertrain.com/images_w2w/...ANCE-SHEET.pdf
Our 402 N/A version can also handle enough nitrous to make close to 900 at the flywheel.
Old Feb 8, 2006 | 06:52 PM
thinkBIG's Avatar
Thanks for you input guys and thank you W2W for responding to this thread.
Old Feb 9, 2006 | 03:05 PM
Kevin@W2W's Avatar
LS1TECH Sponsor
No problem.
If you have any other questions feel free to contact me.
