Check my math really quick
Old Feb 17, 2006 | 11:01 PM
camaroextra's Avatar
Default Check my math really quick
To get 396ci out of a stock bore ls2 you would need a 3.939inch stroke correct?
i dont know engine equations, but i know general geometry
the stock bore is 4.000right?
2.00radius^2 X 3.141592 = 12.566
396ci/12.566/8cylinders = 3.939
am i correct?
Old Feb 17, 2006 | 11:05 PM
CAT3's Avatar
Restricted User
I use this math.... http://www.wallaceracing.com/calccid.php which says yes 395.99 ci.
Old Feb 17, 2006 | 11:16 PM
jrp's Avatar
jrp
SN95 Director
yes, i get 395.991470799686
however an easier way would be 4.020 and 3.900 stroke; 396.001272568765. but really, why bother when a 402 can be had so readily.
Old Feb 18, 2006 | 12:12 AM
gun5l1ng3r's Avatar
Would the decrease in stroke allow the motor to rev a little bit higher(dependent upon valvetrain) and maybe rev a little faster?
I have been reading some of the posts regarding rod/stroke ratio and the effects of piston speed on motors. I think I understand that just by decreasing the stroke, you don't necessarily increase the ability of the motor the rev higher or faster.
But then why did the DZ 302 from the 60's rev so mich higher and faster than the 350's of the same era? Was it due to the solid lifters of the DZ 302 and possibly the shorter stroke of the engine?
Edumacate me sum!
PS It would be cool to have a "396" and I have always wanted a small block that revved more like a Ferrari motor than a Chevy motor
-Jake
Old Feb 18, 2006 | 07:03 AM
i want just curious what building a modern 396 SS would involve, since it was one of the engines used in the camaro, once a get a daily driver
