FAST intake for LS7 heads
Old Feb 24, 2006 | 02:49 PM
Abdullah's Avatar
Default FAST intake for LS7 heads
is there a FAST intake for LS7 heads that will fit LS1 and LS6 camaros/vettes?
why FAST doesn't make an intake manifold for those heads?
you know with this intake manifold ( stock sensors locations..etc) you will be able to use the LS1/LS6 camaro/vette's stock PCM.
Old Feb 24, 2006 | 02:51 PM
Mizfit MotorSports's Avatar
LS7 intake looks to flow better then the Fast intake. We will have some numbers soon we have a couple of projects in the works with LS7 stuff.
Old Feb 24, 2006 | 02:54 PM
mr2guru's Avatar
I wonder if someone will make a spacer for cable throttle bodies and the LS7 manifold.
Old Feb 24, 2006 | 03:27 PM
gollum's Avatar
What we need is a conversion kit so we can use the OEM Corvette LS7 intake with OEM and aftermarket LS7 style heads.
Old Feb 25, 2006 | 11:22 AM
Our website will be up and running by the end of the weekend. Go and check out our Turnkey 427 package. We have a spacer in the works.
Old May 14, 2006 | 06:52 PM
SSPerformance's Avatar
take it no go on the intake spacers?
Old May 14, 2006 | 07:12 PM
67camaro's Avatar
intakes that fit LS7s wont fit ls1/6, and intakes that fit ls1/6 wont fit ls7.
they've been able to use cable tb's on ls7intakes for a while now...look around im sure you'll find it
Old May 14, 2006 | 07:46 PM
thats was regarding it fiting onto a ls1 style motor
Old May 14, 2006 | 08:00 PM
67camaro's Avatar
oh i was reffering to this post:
Old May 14, 2006 | 09:55 PM
Abdullah's Avatar
intakes that fit LS7s wont fits ls1/6, and intakes that fit ls1/6 wont fit ls7.
i meant FAST intake (for LS7 heads) that fit (the FAST intake) LS1/LS6 style engines not FAST intake that fits LS7 engine.
Old May 14, 2006 | 11:26 PM
Beast96Z's Avatar
Your posts are very confusing. All I can gather is that you want a FAST intake for a LS7 that fits the LS1/6 engine? In either case, nothing about the 2 motors are the same. LS1/6 heads carry a cathedral port whereas the LS7's carry a rectangle port. Even if there was a FAST LS7 intake, it would not work on a LS1/6. The reason there isn't a FAST LS7 intake is because the OEM LS7 intake seems to be better than a FAST LS-1/6.
Old May 15, 2006 | 12:03 AM
Abdullah's Avatar
i meant FAST LS7 intake and LS7 heads that fit on LS1/LS6 engine with its wiring harness, throttle cable...etc (of course with 4.125" bore or better). i don't want LS1/LS6 heads.
Old May 15, 2006 | 12:26 AM
Nate_Taufer's Avatar
Dude a production LS7 intake outflows a FAST 90 mm LS1/2/6 manifold by a good margin. Just use the LS7 manifold if using LS7 heads. Done and done.
Nate
Old May 15, 2006 | 01:06 AM
Abdullah's Avatar
Nate
Nate, i thought a Fast LS7 intake would be better than the stock LS7 intake. i didn't mean to compare the "could be" Fast LS7 intake or the stock LS7 intake to the Fast LS1/LS6 intake.
Old May 15, 2006 | 10:58 AM
Big-DEN's Avatar
The "could be" FAST-LS7 would be a redesign long runner intake designed
specifically for LS7 heads. It would have to do better than a "cleaned up/ported" LS7 intake can do. Which "gregfell" has doing to 360CFM with the heads attached.
The "could be" FAST-LS7 can change plenum size, runner length with similar design to the factory.
It'll be something coming...
