LS7X 12 Heads
Old Feb 27, 2006 | 09:41 AM
ClifZ28's Avatar
Default LS7X 12 Heads
I was looking at these heads in the latest issue of Hot Rod. I was just wondering if the bolt hole in the port floor, and the access hole with a plug in the port roof will hurt flow characteristics on a N/A motor, or does it not really matter? Would it be better to not have these "holes" on a N/A motor?
What would be the smallest bore size that would be compatible with these big valve heads. I think the Intake Valve is 2.20".
Thanks
