LS7 parts Questions
My questions are: Would the ls7 crank work well with my application or would I be better off going with a more expensive callie crank etc.? Has anybody compared (dyno) the ls7 intake against the ls2 intake and all the aftermarket intakes? Are there flow numbers yet on the ls7 heads?
If you want to run the LS7 heads... or even the World LS7 heads then you'll need the GM LS7 intake or the GM LS7 single plane carburator style intake... or go custom sheet metal.
