Big springs on an LS7 head
Old Jan 13, 2006 | 09:38 AM
LOnSLO's Avatar
Default Big springs on an LS7 head
Anyone have a guesstimation on how big you can open up the spring pockets on these heads without going into the intake runner? I am trying to find out before I order a set. I need a 1.550" at the minimum. Also, are T&D or Jesel making some sort of shaft mount setup for these?
Old Jan 13, 2006 | 10:49 AM
427's Avatar
427
We used Jessel rockers on ours. The head is very thin on the outside valvecover rail where the spring machining intersects, you may hit water cutting for 1.550.
Kurt
Old Jan 13, 2006 | 11:08 AM
LOnSLO's Avatar
Kurt
Ok Kurt, thanks. I will be able to look at a set in about a week to see what I can do with them. Does not sound promising though.
Old Jan 13, 2006 | 11:23 AM
DavidNJ's Avatar
However, the World heads available in 2-3 months won't have that problem.
Old Jan 13, 2006 | 11:27 AM
LOnSLO's Avatar
This is true, and our shop is a WD for World, so that helps.
Old Jan 13, 2006 | 02:00 PM
Greg Fell's Avatar
I'm looking at K-Motion K800's...not sure if these will work for you...will you be running a solid roller?
Old Jan 13, 2006 | 02:55 PM
427's Avatar
427
The All Pro head that is available now does not have a problem up to 1.625. I have also put 1.650 on my AFR heads with some forethought and planning.
Kurt
Old Jan 13, 2006 | 03:09 PM
LOnSLO's Avatar
I need 300# on the seat.
Old Jan 13, 2006 | 03:14 PM
Phil99vette's Avatar
7 Second Club
DAMN! 300# on the seat, whats that look like over the nose? Pro-stock motor?
Phil
Old Jan 13, 2006 | 06:37 PM
DavidNJ's Avatar
Phil
And what was that 1.650" for?
Wow...real springs on an LS1!!!
Phil, what did you use?
Old Jan 14, 2006 | 08:34 AM
7 Second Club
I think they are PSI 1224 springs.
Phil
Old Feb 25, 2006 | 02:29 PM
Greg Fell's Avatar
Richard at WCCH cut his to 1.550 with no issues.
Old Mar 1, 2006 | 10:57 PM
airflowdevelop's Avatar
you can step ledge the spring seat with a cut down locator, and use a hardened steel for wear.
There is no reason for 300#'s on the seat, there are many high rate durable springs today to give nose pressure for the wildest of grinds and spare seat pressure. It is not possible to get enough valvetrain mass in this motor to require that pressure on the seat! AND remember seat pressure is WASTE HEAT! loss of valve control occurs directly after the nose...not the base of the lobe.
we have evolved from the days of the 94x pacaloy springs (even though they are some of the best springs made). Different ways to skin a cat!
