LS7 Fuel Rail and Intake Manifold ...
STF veteran / 10 second club
I'm putting an LS7 intake on my new ET heads, but I will need a new fuel rail and injectors. I've heard the stock LS7 injectors are 42#'ers or so, is this true? Also, will the stock LS7 fuel rail connect to the LS1 fuel line in a C5?
Would it be better to use a standard LS1 fuel rail, and normal LS1 style 42# injectors, or the LS7 setup?
Looking to support 550rwhp, with a stock feed line and racetronix intank pump ... car will be tuned with LS1 edit on stock LS1 pcm.
Thanks
Thanks
LS7's are good for some serious horsepower. Yes, they are 42 lb/hr. The only thing you will have to do is chop the harness for the new injector.
I guess you could go with the ASA/3.8 SC injector, get the Katech o-rings and have them make up a spacer kit, because the one they have won't fit.
Yes, the fuel rail will fit right on.
Thanks
Thanks
I'll let you know when our spacer kit is ready.
Thanks!
Originally Posted by vmax1500
Roughly when will the kit be ready... and what exactly does it include/do? I am going with a simmilar setup as xphantomws6x and want to know what other parts are required to make an LS7 intake/heads work on an LS2 in an F-Body...
Thanks!
Thanks!
It's 4 spacers, 10 o-rings (2 extra) and 4 bolts to use LS1 injectors on the LS7 manifold. It might be a couple weeks before the kit is ready. CNC is very busy and then they need to get anodized.
ls1-7
From what I see, The LS1 fuel rails will not work. THe angle of the dangle is different between the fuel rails and injectors. the LS7 injectors are straighter up and not canted as much. I am making fuel rails for mine right now so I can use Fast injectors and their harness.
I think it will be a killer setup for a 402.
I heard that the cable NW 90MM TB causes a lean condition with the LS7 intake... is there any truth to this... and how much is the kit? Thanks!
There is no truth to that. We use the UMI cable TB on our LS7 engines on the dyno with no problems. I have also confirmed from Myron @ TPIS that he has not had any problems with 90mm cable throttle bodies either.
Thanks...
I was told that the NW TB opens in the opposite direction of the LS7 TB and that is what causes the lean condition... does the UMI or TPIS open in the same direction as the NW?
Thanks...
Thanks...
$24.99
Call 866-KATECH1
Call 866-KATECH1
Thanks!
I will be ordering this kit... what else is required to install an LS7 based motor into an Fbody? Will this kit allow me to keep my LS1 style injectors and stock fuel rail... or will I need a new fuel rail... If I need a new rail, does it have to be LS2 or LS7 and how much do they go for?
Thanks!
Thanks!
