ls2 swap
Old Mar 18, 2006 | 03:14 PM
98charlize's Avatar
Cool ls2 swap
hey guys i have a 98 z28 and would like to take out the stock ls1 and put in a ls2. i just don't know what i will need to buy to have this done the right way. and if you guys have a ball park price for parts, engine and all that would be great. thanks guys
Old Mar 18, 2006 | 04:30 PM
kmdracer's Avatar
I've been kicking this around also. Last I heard there was a problem with the knock sensors not working right. I 'm trying to find out if anyone has solved this or do the knock sensors still have to be turned off.
Old Mar 18, 2006 | 04:49 PM
HSV-GTS-300's Avatar
https://ls1tech.com/forums/showthrea...2+knock+sensor
Old Mar 22, 2006 | 09:40 AM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
Default LS1 to LS2 Change Over
The short block that we sell comes with all of the change over parts needed to go from LS1 to LS2 except for the knock and cam sensor harnesses. They will be another $52.00. Everything else from your LS1 will transfer over.
Brian
Old Mar 22, 2006 | 11:19 AM
Redomy98z28's Avatar
Good to know info, I am also having an LS2 put in to my f-body.(98Z28)
Aside from the ECU, drive-by-wire, and wire harness, are their any other adaptations that need to be made to fit the LS2 into an f-body.(taking into consideration the components listed above.)
Thanks
Old Mar 22, 2006 | 11:24 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Thanks
ECU solution: Use the LS1 ECU w/ 24x trigger installed
DBW solution: UMI throttle body (which we carry)
Wiring harness solution: Cam/Knock adapter harness, MAP extension harness
Injector solution: Use LS1 injectors with our spacer kit
Old Mar 22, 2006 | 11:31 AM
Thanks for the additional Info. I'll be sure to bring some business your way.
Thanks again
Old Mar 26, 2006 | 07:52 PM
quick98z28's Avatar
sdpc sells a kit with dowels valleycover plugs and the wires everything you need to swap a ls1 to a ls2 , i started with bare block and needed everything they can take out the dowels and plugs depending on what all you need. im putting a 402 in my 98z after my tranny gets back
