new alum. block can get 455 cu. in.
Earlier this week I saw a post about a new aluminum block that can go up to 455 cubes AND fits all LS1/LS6 components. Can't find the post. Any help?? Tnx in advance.
Are people really "ripping head studs out of the block under high pressure" ??
I've heard of lifting the heads but I thought that was dues to cyl head flexing. I've never heard of pulling the threads on a block.
Stock LS1 aluminum block bored / stroked to 455ci for GTO package, done by MTI.
Here's their ad page: http://www.motorsporttech.com/print/...rochure01.html
And some background info from High Performance Pontiac: (Behind-the-scenes engine buildup, with components named)
Part 1 http://www.highperformancepontiac.co..._ls1_455build/
Part 2 http://www.highperformancepontiac.co...s1_tests_dyno/
Either way, the World Products block and heads should take care of these problems as they have 6 bolts per cylinder rather than the standard 4 bolts per cylinder that all other LS engines have (including the ERL block/deck plate system).
